Samsung HCM422W 42" Rear Projection Television Logo
Posted on Mar 17, 2009
Recieving hd on the samsung sp42w4hl
I have a samsung sp42w4hl television and would like to know what cables are required to connect a freeview box to recieve HD channels,the cables i have already brought dont fit into the back of the TV are scart leads suitable?.
5 Related Answers
Anonymous
  • 579 Answers
  • Posted on Jan 01, 2008
SOURCE: SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
A
Anonymous
  • Posted on Nov 09, 2008
SOURCE: my samsung ps42c96 HD tv
try changing scart cable
Anonymous
  • 210 Answers
  • Posted on Nov 29, 2009
SOURCE: how do i get high definition picture ?
you need a HD tv and a HD recievre e.g SKY HD
Anonymous
  • 111 Answers
  • Posted on May 19, 2010
SOURCE: how can I recieve hd channels i have just had a hd
the cable or satellite box should also have a component input which is the red,white,red,blue and green cables.these will also provide hd quality
Anonymous
  • 17 Answers
  • Posted on Jul 23, 2010
SOURCE: displaying HD1080i on HLN507w
you can get a dvi/hdmi converter at target
Freeview frozen on ch 19
Is this connected to cable, sat or dsl box. If so your issue is with this external box not the tv. If the tuner in the set is used the do auto scan in setup menu.
I have a Samsung LE26R8 tv which is HD ready, It has built in freeview will i get HD channles or will i have to get a HD tuner
Hi, Your TV is set for HD but you will need a set top box. (PVR) You will need a digital decoder to recieve HD or digital channels. Talk to your cable or dish companies for more info. Good luck.
I would like to delete some inappropriate channels on my freeview. i have tried to put parental control on, but it hasnt worked!
It sounds to me like you need to block the channels on the converter box for freeview. The television parental control will only work if you are using basic cable hooked directly into your tv. Otherwise, all of the channel control functions are handled by the control/converter box from your service provider. If you do have cable hooked directly into your set, try consulting the owners manual either online or the copy provided with the television. Good luck, Russmann.
1helpful
I have a freeview build into my tv which is Panasonic plasms tv Model no. TH-46PZ8BA and wish to know how I can receive HD channels BBC or ITV. Please advice and help.
HD Ready just means the tv can display HD images from an HD source.
The built-in Freeview box on your tv is not Freeview HD compatible so you'll either have to buy a separate external Freeview HD box or subscribe to an HD satellite or cable service.
In any case, most built in Freeview receivers are of barely adequate picture and reception quality. An external box is usually far better in both respects.
How can I recieve hd channels i have just had a hd box fitted but there is nowhere to fit the hdmi cable to the tv
10helpful
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Freeview
go to menu settings, channel settings, set tv to CATV for cable, AIR for analog, or HD for high def.
Make sure you have the correct cables depending on your connection
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
4answers
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
