The hard drive light is on and there is nothing going to the screen, also fan continues to run non stop, i have changed the power supply but still no luck
SOURCE: no booting or nothing
Narrowing down a fault like this is relatively easy but time consuming.
Please read this thread about building your machine outside of the case.
http://forum.pcmech.com/showthread.php?t=132409
The idea of an "out of case build" is to reduce the amount of hardware in order to eliminate what is causing the problem.
I build computers eveyday and I still use this method from time to time when trouble shooting.
SOURCE: it wont run programs
remove the RAM chips,blow off any dust that musta settle'd on it...and swap them into diff slots
SOURCE: Acer Aspire M5641 has a
if by pushing on the power button the machine does not immediately shut down, and you have to hold it down for 5 or 10 seconds, this would indicate that the system is fully functional. the problem would be , your monitor or integrated graphics (NVIDIA GeForce 7100 / nForce 630i) are bad. the graphics can be resolved by adding a graphics card to your system for a reasonable price that varies from 25.00 to 85.00 dollars. the proper card would be a PCI Express video graphics card. here is a link that will provide you with many different options suitable to your need. i suggest you take into consideration if you are a gamer , that you aquire one equal too or greater than 512 self supported ram. 512 will by far exceed the factory video capabilities, enabling a much higher quality video resolution and clearer video /gaming viewing.
http://shop.ebay.com/i.html?_nkw=nvidia+geforce+pci+e+video+512&_sacat=0&LH_BIN=1&_odkw=nvidia+geforce+pci+e+video&_osacat=0&_trksid=p3286.c0.m270.l1313
Testimonial: "I got a PNY Graphics Card in local BESTBUY for $64.94, and inserted this card, but since i can't change the bios setting, so i still have black screen"
SOURCE: Have Acer L410 and it
Sounds like it might be a Hard Drive Issue if you have heard any strange noise comming from the hard drive the Just think about replacing it with a new one .
If I can be of futher assitance feel free to contact me by posting on this page
