Funny noise? Will it talk any word? Listen well.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
ok its a thought off my head that i can think of right off
the brake on drivers side is binding and the squiller pin i call it is rubbing on rotor you probably need a brake inspection there free at brake masters
Power supply is blown. Google it, check ebay (with tv model name) or just part it out and get a new one. You can also buy these used for really cheap off of craigslist.org
Is the noise from the PSU brick or the unit? Or is it coming through the TV with the sound from the game? Sounds like something is shorting in the PSU brick - if so it will eventually stop working. Contact nintendo if under warranty still or source a replacement PSU on ebay etc.
It is most likely a fan (there are 2 to 3 of them in the set) that is making the noise. I doubt seriously that the lamp is causing a buzzing noise. The only other buzzing sound can come from the ballast wich powers the lamp.
