Question about Apple iPhone4 4G iPhone 4
Sim Card Problem
Phone keeps saying no sim card when there is one
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Won't detect Sim Card
Calm down. Could be a number of things causing lost service. Restart the PC with iphone disconnected. Bring up itunes, plug in iphone and let the activation sit for a couple of minutes. If status does not change about sim card, eject the sim card using a paper clip, insert that paper clip into the tiny hole on the top of the phone. disconnect the phone, insert the card again, and reconnect. Let me know if this helps.
Posted on Sep 27, 2007
Anonymous
SOURCE: iphone sim card problem
i put the sim card into iphone is dont work
Posted on Sep 13, 2008
Anonymous
  • 16 Answers
SOURCE: Cannot import contact from sim card to iphone 3G
Turn off the iPhone before inserting the sim, insert sim, turn on, import contacts. If you put the sim in the phone without restarting it for some reason it doesn't get all the contacts sometimes.
Posted on Oct 01, 2008
Anonymous
SOURCE: insert sim card
i dont know wedre the sim card goes in the iphone can u help
Posted on Nov 30, 2008
Anonymous
  • 40 Answers
SOURCE: I DONT HAVE A SIM CARD FOR MY IPHONE AND IT WONT LET ME IN
you will need to call att if that is your provider and you will need to report a damged or lost sim card. or go to your providers store and ask for on and they will be able to help you. sorry, you actually need one of them to get past. no other way
Posted on Aug 07, 2009
My nokia phone keeps saying its off line
have you tried using different Sim cards? check if the network status is made offline,if yes change it.if you have a Sim card inserted and when you change the profile to general it shows that 'please insert a Sim card' ,think that your sim needs to be changed.try using another Sim card and post the result here.
Apr 03, 2012 | Nokia 5230 Cell Phone
I put a lime sim card it keep say insert correct sim card what is the correct sim card
If it says insert correct Sim card in the Phone means it locked to some Network,You need to Unlock it...You need to specify the Network ,Country,Brand,Model...then get the Unlock code at here Classicunlocking.com and Unlock it...Then You can use any GSM Network Sim card.....
Aug 03, 2011 | Cell Phones
Phone Keep saying " Sim
Hi! The phone might have been black listed (blocked) or you might not be inserting the sim card correctly.
To find out if your phone has been blacklisted then you could ring up your network provider and give them your phone serial number and they should be able to tell you straight away.
There could be a problem with the connection port of the sim card.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply
Mar 01, 2011 | Nokia E63 Cell Phone
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 | Cell Phones
My phone keeps saying missing sim card or initialization failed? i have taken out and put back the sim card and battery and nothing works
whats your phones model number anyway check with this the sim card slot you put may be expanded there will be a small cap like enclosure on the sim slot try to bend it and again insert the sim the sim card should be holded tight or else keep a small paper on above the sim card and close the battery you get a solution. thank you
Oct 18, 2009 | T-Mobile BlackBerry 7105t Cellular Phone
MY SIDEKICK 08 KEEPS SAYING NO SIM CARD EVEN WEN
I just got a sidekick off the internet and I put my SIM card in the phone and it says no SIM card. What do I do? Anyway to fix whatever is wrong?
May 30, 2009 | Sharp Sidekick LX Smartphone
Says insert smart chip
smart chip means the SIM card.
try cleaning the metallic part of the SIM card with a cloth and the metal connectors on the phone with cotton bud etc.
Put it back and try again.
If not working grab another SIM card (working - friend's etc) to test.
If still not working, send to service centre.
If working for other SIM card then replace your own SIM card.
May 29, 2009 | LG Vu CU920 Cellular Phone
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Sim card rejected
Try inserting the sim card in another phone. If it still doesn't work, the problem could really be with the sim card. Go to your service provider, and request for your sim card number transfered to another sim card. That is if you wanna keep the same number. You could request for another sim card if you'd like. Call your service provider.
Jun 27, 2008 | Lands Phones
Inactive sim
I know this is a silly question but are you putting the sim in correctly?
Dec 09, 2007 | Sony Ericsson W850i Cellular Phone
Apple iPhone4 4G iPhone 4 Logo
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
