Question about JBL MR-17 Sirius-Ready AM/FM/CD Receiver Controller
Hi So I have a boat there is a radio in door and there is a remote control outdoor so i need the control that you to have to connected to the radio so you can use the remote control from outside th
Hi So I have a boat there is a radio in door and there is a remote control outdoor so i need the control that you to have to connected to the radio so you can use the remote control from outside that's mean when you join the control to the radio and to the remote control so you can used the remote control from outside thx anyway.
    Top Expert:
  • JBL Master
  • 66,560 Answers
FIXYA has no idea what you want or need .try the boat company
Posted on Oct 22, 2017
My Double Horse 7000 RC boat will not run
myy was working then stoped. Battery was full. I disasemble it and found that the on/off switch stoped working because of the rust (water is getting inside). I manage to make a direct conection solding the black and red wire in this switch. Try it.
Jan 02, 2013 | Double Horse Radio Remote Control RC...
Engines might run for a second but very sporatic battery is good it acts like there is a short in the system
The boat has an issue that is for safety only allowing it to work in water, this can cause sputtering. You can try to connect a copper wire between the two copper drive shafts. The range on this boat is not great so that may be part of it.
Mar 20, 2011 | SYMA Toys industrial 30" RC SYMA Century...
We have a P8? CAN'T FIND MANAUL
P8-Abnormality in outdoor unit.
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have this radio on a 2001 sea ray boat with the wired remote and I can't seem to get the remote to work. Wondering if it's more than likely the actual remote unit or some thing in the wire harness that's...
I know this isn't going to help you but I have a similar issue. The remote will function IF I first turn on the radio from the radio unit itself. Yours should turn on when the boat turns on, as mine did once. Now, my remote will not turn on the radio but will control it once I take the step mentioned above. I suspect I have a faulty remote. Coincidentally my battery now loses it's charge after a couple weeks of no activity. Perhaps a short in the remote unit causes a slow drain.
Aug 12, 2010 | Clarion XMD1-RET CD Player
Where can i find a 2 channel receiver for a 2 motor boat. Right/left and throttle?
Hi DM,
A hobby store, garage sales, craigslist. etc. Another boat.
You need to have the Transmitter and Receiver paired to the same frequency.
You'll find most on either 27MHz or 49MHz. There are also six or so sub frequencies under each you need to worry about.
I can't be more specific than that with the information you supplied.
The motors or example, fuel or electric? Makes a difference.
Best regards
Mike
Jul 22, 2010 | SYMA Toys industrial 2-Channel New Syma...
JVC Marine radio on 2002 Malibu Boat
IT may be to late but you can buy a JVC radio model KD-SX50M tat will be plug and play. I just purchased one for 69.00. I had a simialr situation and that was all it was.
Jun 23, 2008 | Clarion Wired Marine Remote Control
Car Audio & Video Logo
43 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
