Question about Sony Televison & Video
Wrong region I am from Poland and I bought Jwin JD-VD625 last december in USA. I can`t watch any DVD`s produced in Poland. I was searching in Internet and it seems that i am not the only person who have this problem called `wrong region`. How to solve it?
Posted by hcwdpt on
Anonymous
I just found this answer from another contributor.
Turn the power on
Close the drawer
Press 9735
Select Region 0
Exit Setup
You now have a multi zone DVD
Posted on Mar 22, 2009
2answers
2helpful
My jwin model jd-vd509 does not play all regions,how can i change that? iwas given player in macau in macau as a gift,but find that the origanal dvd`s i bought in the uk and australia wont play,it comesn...
Don't know if it will work on your. I have a jWin JD-VD141 and the code works. Have the DVD tray open (means ejected) then press 9735. A menu will pop up and choose Regions 0 then exit. You DVD player should play DVD from all regions.
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
How to connect this entertainment system to existing sony recieve
This is a standalone system. It can't be used with a receiver. Sorry.
2answers
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
2answers
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Wrong Disc
Are you referring to a prerecorded commercially produced DVD?
Discs are Region Coded This means that you will not be able to watch DVDs intended for use in a different country, unless you have a multi region player. .
There are two video standard formats, NTSC which is mostly North America, and PAL which is the rest of the world. Some players will play both, others won't. Some DVD players allow you to select the format.
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
