SOURCE: making noise in planetary gear area
The noise you are describing sounds like the noise associated with the pinion gear meshing with the ring gear in the planetary. Depending on the age of the unit, some noise is to be expected. The lubricant used in the planetary is different than that of the main transmission and is not visible without disassembly. Again, depending on age of the mixer, your planetary may have a small amount of oil and a pump to bathe the gears or just a generous amount of grease applied to the gears. The only way to properly inspect the planetary is to remove it. Depending on your luck, this may be 20 min job or several hours. It all depends on the ease of which the planetary releases from the main center shaft. Should you decide to tackle this job yourself let me know and we'll do our best to assist you. Several knowlegeable techs monitor this area of the site.
SOURCE: inside drawing of varimixer planetary head
The parts breakdown is downloadable at our website at:
http://www.varimixer.com/?xhtml=xhtml/var/us/en/general/parts_manuals.html
Download the W30 "Complete Operations and Parts Manual"
SOURCE: I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Testimonial: "I know,ust can't find them. If you could explain to me how, I would appreciate it"
