Question about Zanussi ZWD1470W Front Load Washer / Dryer
I have an error code on my dishwasher saying ALS anyone know. It is a zanussi aquablast dishwasher D6965
Posted by tina_hill3 on
2 Related Answers
Anonymous
SOURCE: error e51 on zanussi iz12
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Posted on Oct 24, 2010
Dado
  • 509 Answers
E51 does mean "triac which powers the motor short-circuited".
(TRIAC short-circuit cut-out activated or motor speed more than maximum speed)
Possible causes:
Loss of insulation on motor winding/wiring; main PCB
Dado
Posted on Jul 06, 2015
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
My Zanussi DE 4544s dishwasher has this fault, when you put any cycle on it reverts to the flashing green lights......any help would be much appreciated.
You need to go on line to the Zanussi web site and request the error codes for this machine. Once you know what the problem is you can pose a question!
Dec 31, 2012 | Dishwashers
Zanussi ZSF2450 has the pump running but the front panel has switched off - booklet says contact service centre anyone know what is wrong?
The flood switch has tripped, this is either due to water in the base of the dishwasher or a faulty flood switch.
Mar 04, 2012 | Zanussi Dishwashers
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Control Panel
I have not heard of this brand of a dishwasher but It should be like any other. I would say that the control panel for the cycle select is bad and needs to be replaced. You will want to check and see if there is any kind of thermal fuse that may be open and to make sure there is power getting to the control. Also check that the door switch is als operating normally.If all checks out good replace the control bord. Good luck
Jul 19, 2007 | Zanussi 18 in. DE4744 Free-standing...
Zanussi ZWD1470W Front Load Washer / Dryer Logo
50 people viewed this question
Top Zanussi Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
