Question about Digidesign Mbox 2 Barebone
Running digi 001 on windows 7
I want to use digi 001 with windows 7
Posted by eanthanakunn on
  • Anonymous May 12, 2009
    will my digi 001 run under Windows 7?
  • Anonymous May 15, 2009
    i want to know to
Anonymous
I got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Posted on Sep 01, 2009
  • Anonymous Sep 04, 2009
    correction
    sorry about misspelled driver name
    it's: Dalwdm.sys
    didin't have my glasses on x-D
    - veikko-antero
Sangeet Tuladhar
Successful installation of DIGI 001 on windows 7 32 bit
Digi001 works fine with Windows 7 32 bit
you need to have protools 6.4 install in windows 7
since protools 6.4 cannot be installed on windows 7 you have to run the installer in compatibility mode to windows xp. After install any DAW, you can make use out your old digi 001
I am currently running fast track pro on AMD 64 bit system... it makes poping crackling noise... I am not that happy with 64 bit system
driver for DIGI001 is in c:\windows\system32\drivers\ Dalwdm.sys
Posted on Dec 02, 2015
aristeu caldeira (Sigmatron)
    New Friend:
Searched a lot and I find the dalvin.sys file to configure the digi001. You can send me the file dalvin.sys please? Aristeu - [email protected]
Posted on Mar 14, 2015
  • Sangeet Tuladhar Dec 02, 2015
    Dude it's not dalvin.sys
    Install protools 6.4 on windows 7 32bit in compatibility mode to windows xp. After install any DAW, you can make use out your old digi 001
Caleb Varghese
    New Friend:
Veikkoantero : Can you by any chance send dalvin.sys to me ..
Posted on Oct 13, 2014
1 Related Answer
joedirty
joedirty
  • 158 Answers
SOURCE: digi 001 run under Windows 7 64 bit
Currently it wont run on the windows 7 64 bit.
Posted on Nov 11, 2009
How to install the drivers for digi 002 on windows 7
Here is the official AVID page regarding the digi 002 drivers: http://avid.force.com/pkb/articles/en_US/Download/Digi-002-003-Drivers
Feb 05, 2013 | Pro Tools Digidesign Digi002 Mixer Avid
Hi my girl bought a Sitecom vp-001 Webcam and the driver is not working for windows 7 (told her it wont but she no listen XD) anyway can anyone tell me if there is a updated file that can support it for...
Although this camera is not compatible with Windows 7, I suggest to try this download link also (extract the zip file and run the setup file). In case of no luck again, before running the setup file, right click on it, go to properties and at the compatibility tab check the box for windows XP sp3 compatibility and hit apply - ok. Run the setup file as usual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 21, 2011 | Sitecom Computers & Internet
I have celeoron M presario v3000 compaq laptop .Is windows 7 is compatible for that>
veena:
I just checked the HP-Compaq web site for Windows 7 drivers (click here for the site), and they do not provide Windows 7 drivers.
There are Windows Vista drivers that may work with Windows 7, but it will be hit or miss.
Thanks for using FixYa.
Feb 16, 2011 | HP 417065-001 - HP Compaq Presario V3000...
Where can I get the software for the Stratford Labs GFP-001 digital image copier for Windows 7?
The manufacturer's website advises that the GFP-001 Image Scanner is, Compatible with Vista and Windows XP systems Only. Requires USB version 2.0 Only.
Sorry, but I do not believe you will be able to find support for Windows 7, unless your scanner functions with one of the generic drivers inlcuded in Windows 7.
Jan 01, 2011 | Office Equipment & Supplies
Digi 001 run under Windows 7 64 bit
Nov 11, 2009 | Computers & Internet
I'm need tech support..........
1. You should be able to connect the midi up to the digi 001, if not get an 002, 003. The 001 is so outdated and will not support newer pro-tools software especially plug-ins.I know I had the 001. Now with the 003 rack(love it).and PT 7.4. Research how to plug a midi device into PT.
2.Would google EMU XL compatability.
3.refer to 2.
4. No just memory(RAM)
5.cool...yes why couldn't you?
6.You should be able to come out of the digi, then to a power amp, then the BAs
Aug 20, 2009 | Boston Acoustics (BA7800) Computer...
Driver for Digidesign sound card
I do not believe that exsist nor an adapter either. Maybe consider rephrasing what you need to get done.
Nov 13, 2008 | Digidesign Mbox External Sound System
Digidesign Mbox  2 Barebone Logo
15,082 people viewed this question
Top Digidesign Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
matt
matt
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
