Yamaha waverunner 1st start of the season. I put the fully charged battery in with out a problem. Eng tried to start like normal and then stopped trying to turn over while the button was pushed. Now when you press the start button, nothing. No sound or noise. What do you think it is?
and then
Not real familiar with waverunners (this is a car and truck section after all), but remember that when you have been riding and stop engine it gets much hotter. Could possibly be coil "Heat Soak", or even a fuel system vapor lock issue caused by a pinhole leak in a line or a bad gas cap. Not very confident in this, but the best I got. Try posting in the waverunner section.
check all fuel lines are in good condition , check fuel tank pipes etc ! run on a hose ( start engine first ) and look round for leaks ! water off then stop engine ! P...
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
Do you have ignition lights.? Starter solenoid may be stuck, put car in 1st gear & rock it backwards & forwards, select neutral & try starting normally. Have you tried giving it a push & bump starting, if it runs then you got starter motor issue.
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
This is most often caused by a battery that does not have a full charge on it. The low amperage available from the battery causes the contacts inside the starter relay to weld themselves together and allow the electric starter motor to continue to run even after the starter button is pushed. Always start out with a fully charged battery and you will not have this problem.
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
