Question about Baofeng UV-5R PlusEarphone 136-174/400-480Mhz Two-way Radio
Baofeng uv 5ra program
What program to enter frequencies
KenH112
    New Friend:
  • 25 Answers
Chirp
Posted on Jul 19, 2014
On a baofeng uv-5ra. how do i change freqs. on channell mode? frequency mode works fine but it won't let me change the freqs. in channell mode. thanks.
You have to be in "VFO" mode. Your best bet on that extremely difficult to use radio, is to get "chirp" and the proper cable and program it via a computer. If you search on-line for "baofeng programming" you may find an alternate set of instructions. Your absolute best bet: throw that PoS away and get a Yaesu FT-60.
Baofeng uv 5ra manual
The Baofeng manuals are terrible. Look online for "Baofeng UV-5R programming" Setting up and programming your UV 5R
I programmed my Baofeng UV-5R to a UHF repeater frequency and entered the proper CTCSS code. I also correctly entered the correct offset which allows me to connect to the repeater. Howerver, when I
Please. Your question got truncated in the title, and was not asked in the details. So I have you asking, "However, when I..." and that this is occurring on your UV5R. Please respond with details and I will try to help you. I own the UV5R+.
There is an excellent owner's manual for the BaoFeng at Miklor.com/uv5r/userguide.
Uv-5ra programming
The problem I found with the programming software was with the driver that is included with the software. Google Baofeng software driver and follow the instructions on how to load as well as how to remove the non-working driver. If you don't remove the original driver, windows will revert back to the original instead of using the new driver. Good Luck!
Be sure the programming settings "Baud rate, etc" are properly set and you have entered the correct key combination to enable the interface on the radio.
Baofeng uv=5ra and uv-5re
One has the band limits set for the Americas, the other Europe. Thus the "a" and "e" in the model numbers.
Baofeng UV-5R PlusEarphone 136-174/400-480Mhz Two-way Radio Logo
Top Baofeng Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Baofeng Radio Communication Expert? Answer questions, earn points and help others
