Here is a video that will help you
Testimonial: "Thank You! I appreciate your time. However, my Bissell ProHeat 9500 2X has the water heater on the bottom not on the handle. I did finally opened it and cleaned the water heater, which was not dirty and cleaned all the lines. After putting everything back, I then found out/figured out that the water tank gasket was the problem. As soon as I get the part I'll see if that does it. :-)"
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
SOURCE: bissell 2x wont **** up the dirty water
My machine would not **** up the dirty water either. I tried everything, read the "troubleshotting" section in the manual and nothing worked. Then I discovered there is a little FILTER that is not mentioned anywhere and is hard to see. It was clogged with dog hair. It is in one of the two removable sections on the top of the machine. It is NOT in the bladder section but the section with the dial to switch from floor to tool. It is red and about 1 inch long. There is a little door on it that you flip open (it actually looks like you can remove it). Flip the little door open and you will probably find a bunch of gunk. Remove it and the machine should work perfectly. Mine now does! Good luck.
SOURCE: bissell 9500 2x deep clean (NO SUCTION)
Like everyone else (!) your lint filter is probably clogged. It is located on the top clear palstic section (the one with the dial to switch from tool to floor use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Flip the door open and you will probably find it is clogged with hair, carpet fibre., etc.. Clean it out and you should have suction again.
SOURCE: I have bissell proheat 2x 9200 no water or
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
SOURCE: Bissell Proheat 2x TurboDoes not pick up the water after cleaning
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
m,nb
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
