Question about Crosley Cr6001a Turntable
Record continously skips after 4 or 5 seconds.
Hi, IK've just received the CR6001A as a gift and it is my first record player. I've set up the playert as instructed, but when I put on a record, I hear the first 4 or 5 seconds before it starts to skip. No matter where I place the stylus on the record, the problem persists. The player is on a level suface (the floor). the needle looks okay, but as this is my first player, I'm not quite sure what to look for. Sound quality is fine! Hope someone can help!
Posted by Jesse Gainer on
Grubhead
  • Crosley Master
  • 5,720 Answers
You need to apply more pressure to the stylus. This is done by adjusting a weight on the other end of the arm. See your manual for more details.
Posted on May 19, 2013
5 Related Answers
dewan nafees ahmed
  • 1894 Answers
SOURCE: crosley cr249
then the recording head is facing the problems sir.
amy be small loose connection in the circuit.
if u r expert in electronics u can fix it easily
Posted on Jun 19, 2008
Anonymous
  • 4 Answers
SOURCE: Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Posted on Feb 10, 2009
Anonymous
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
Anonymous
  • 240 Answers
SOURCE: usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
Posted on Apr 02, 2009
Anonymous
SOURCE: everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Posted on Oct 12, 2009
Dish dvr 622 will not record two shows at once
Deborah Haviland,
I can understand the concern with that receiver not doing the 2 recordings. There isn't a specific setting that stops it, so the receiver itself may be having trouble. Unplug the receiver for 10 seconds and plug it back in.
If the problem persists we would have to replace the receiver. If you can send me an email at [email protected] with the account or phone #, I can definitely check into that with you.
Tommy Faust
DISH Social Media Representative
Every record skips in different places
You should look for an anti-skate control on the turntable and adjust that. It will be a question of trial and error with it as there is no fixed rules for these. The weight on the back of the arm should be set to the weight of your cartridge.
Needle skipping towards end of record
If you lower the tonearm to the record surface, and it just slides towards the center, chances are the stylus(needle) is either broken or covered with dust. Clean and inspect. For more information, please visit my website at audioserviceclinic.com. Thank you.
How di i get a list of the programs that i have set to record? is there anyway to delete programs before they record? on dish tv i could get a list of programs that i had scheduled to record and i could...
These answers should be in the instruction manual.
If you've not got one go to the manufacturer's website, enter Customer Support or Technical Support and you'll find usually easy steps to follow to get a free download.
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
1helpful
I have a Panasonic pll multiplex circuit and when I put a record on it skips a lot. I have another record player at my other house and it has an adjustable weight on it, and I am thinking that that's...
Most likely needs a new needle. Try needlelady.com or needledoctor.com Modern record players usually track at 2 to 4 grams of pressure. Thats about as much as a penny weighs maybe. Putting more pressure on it, will only cause it to destroy your records or sound bad. Weight adjustment is usually a very fine spring or counterweight that adjusts on the tonearm. Linear units use optical sensors to keep the tonearm aligned, but use traditional counterweights to control force. You need a gram scale made for phonos to properly adjust it. Radioshack USED to sell them 30 years ago, but most times you can just use a guess if the needle only slightly deflects when placed onm the record your usually good. If it's simply jumping and sliding across the record then the needle is shot. Even diamonds don't last forever,. as they are synthetically produced.
1helpful
Want to know if it is possible to hear a record player through the AUX plug out? since my Yamaha RX-V396 receiver doesn't have a phono plug out
hi,
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
1helpful
2answers
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Crosley Cr6001a Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
