Kitchen Appliances - Others Logo
Anonymous Posted on May 12, 2013
Portable emerson ice machine
The ice maker is empty & the ice full light is on but I can't get it recycle and start again. The basket is empty and machine won't cycle?
Todd Buchanan
Level 1:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Contributor 18 Answers
  • Posted on May 20, 2013
Todd Buchanan
Contributor
Level 1:
Filmmaker:
New Friend:
Answers
18
Questions
Helped
4817
Points
39
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
5 Related Answers
Anonymous
  • Posted on May 14, 2008
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Anonymous
  • 286 Answers
  • Posted on May 13, 2009
SOURCE: Ice maker not completing cycle
You need to check the thermostat setting. If its set too cold it will never dump ice. Warmer the setting the more ice it will make.Also check the temp. If it should be 10-15 degrees. If its 5 degrees then turn thermostat to warmer setting.
Anonymous
  • 286 Answers
  • Posted on Jun 23, 2009
SOURCE: U-line 95 ice maker
This problem is due to the timer motor in the faceplate of the icemaker. Replace the faceplate part #150 and that should takecare of your problem
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Mar 15, 2010
SOURCE: Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks for your suggestion"
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Apr 04, 2013
SOURCE: My scotsman ice machine have a switch board that keep showing me red light on refrigeration and won't make any Ice.
Scotsman provides a lot of service manuals for their ice machines. It will really help if you could provide a model number so I can possibly find the correct manual and information that just may help you, Thanks Sea Breeze
I lost the manual for my cooks essentials portable ice maker. Help!
Sorry. Neither Amazon, nor Ebay, nor QVC, nor Wayfair are even able to pull up a used Keystone Cook's Essential Ice Maker available, much less a basket for one. Amazon has a bunch of replacement baskets, none of which fit your unit. Home Depot has portable ice makers but I didn't see replacement baskets there. I tried to find the manual for this ice maker and couldn't. QVC didn't have a customer service number for Cook's Essential in spite of having sold the product. And I can't find it elsewhere. Maybe the customer service number at Cooks Direct has access to such information. 8666132617. I've taken a deep dive and can't find what you are looking for. https://www.homedepot.com/b/Appliances-Ice-Makers-Portable-Ice-Makers/Removable-Basket/N-5yc1vZ2fkour4Z1z0v5nb
https://www.amazon.com/Ice-Maker-Replacement-Tray/s?k=Ice+Maker+Replacement+Tray
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Where does the water go in the model IM90 emerson ice maker
open the lid and remove the plastic ice basket. Look on the walls under the ice basket and you should see a "fill line".. Water should be poured into that area (below where the basket goes) no higher than the max fill line.
Ice full light on
There is a float switch or sensor in the basket. Have you got a manual?
Cme256 scotsman
Remove and clean or replace the bin control sensors ( set of two ) part number 11-0540-21. Most of the time you can remove them and clean the little lights and this will do.
Nespresso won't reset after emptying capsule basket. Lights flash as if basket is still full or water is empty??
Call company ASAP..
and they may give you a new one..
after my research.. many have a lot of troubles,
some are different than yours.
or call 1-800 555 1212.. for company information
to call company..
Bummer not having Coffee when you want it.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
