How do I release the DVD drive from the motherboard on an Ibm A31? I can't seem to find the release mechanism to slide out the drive so I can reach the screws to the Ultrabay.
The drive does not release when I pull the lever. There is some mechanism that needs to be disconnected in order for the drive to slide out. The video shows the drive sliding out easily. However my drive will not release in this manner.The drive does not release when I pull the lever. There is some mechanism that needs to be disconnected in order for the drive to slide out. The video shows the drive sliding out easily. However my drive will not release in this manner.
Actually there is a plastic catch that must be released by disassembling the thinkpad. Your video is inadequate in that it doesn't show this particular method that must be used to remove the DVD drive from the Ultrabay.Actually there is a plastic catch that must be released by disassembling the thinkpad. Your video is inadequate in that it doesn't show this particular method that must be used to remove the DVD drive from the Ultrabay.
You can't post conmments that contain an email address.
Look for a screw that might be holding it in and take the screw out. Some times there is a screw that prevents the latch from sliding out.
Mainly this is for shipping purposes to hold everything tight so you will not hurt anything by taking it out. Some people just throw it away after taking it out.Look for a screw that might be holding it in and take the screw out. Some times there is a screw that prevents the latch from sliding out.
This is bad news, the smell you have noticed from the ThinkPad is most likely caused by an electrical short in the power circuit and the cost of repair would not be a cost effective solution, a replacement motherboard may not be available because of the age of this model ThinkPad.
You maybe able to retrieve your data from the hard drive by removing the hard drive and connect to an USB hard drive adapter then connect it to a working computer's USB port. This computer will see this drive as an external USB hard drive and you can copy the data off this hard drive.
The multimedia hardware refers to the DVD/CD drive.
This drive could be faulty or it needs reseating.
Remove this drive and insert it into the laptop again. There is a small slide button next to the drive near the RH corner, slide it and a drive tab will pop out. pull the tab and the drive will slide out, press it back in and the tab. Bootup the laptop and put a CD or DVD into the drive to see if it works again, if not then it most likely is faulty.
If possible put this drive into another A31 laptop to test.
Laptop BIOS passwords are kept in a special password chip. On some laptops these chips are replaceable and there are a number of places you can buy this. PWcrack.com for one.
if your OS is Win XP then UR MBR has gone currupt . You will have to reload the windows or at least repair it.
1. in repair you wont lose the data but in fresh loading of OS in C drive will delete your data in My documents and at desk top.
2. if there is some important data there then first retrive it by making ur drive as slave in other PC and then do the format.
u can buy any things from ebay. because ebay is worlds largest online shopping place for online. from ebay u can get new things and old once too. means if u want to buy cheap things u can buy used but good in condition items. just enter your quote about items and get your choosen items. also u can buy items from buy.com. nowadays buy.com has lanched google checkout offer. in this offer u can get nice %of off on any item.
if u have any question feel free to ask me.. chirag
