Any ideas? I haven't refilled the hot tub yet because we had to drain it this winter so it didn't freeze before we could fix it. I'm not sure I have it hooked up in the panel to the right place with the other wires going to the right places. Do I need water in the pumps for it to run?
SOURCE: I have a Balboa Instrument
Hello there, what i think is the problem with your unit is the control board. The control board is usually responsible for the general functions of the unit. If the control board has a minor problem it would affect the entire units functionality. Although the problem should be minute and repairable so you wont need to replace the entire board which could be very expensive. this is evident from the unit still coming on and starting the pump. Simply get the entire board taken and and checked for the irregularities on the board.
hope this solution has been helpful?
Thank you for visiting FixYa.
SOURCE: Pump 2 not working with an HS200 M7 controller
There are fuses in the controller: http://www.premiumleisure.com/Manuals/MarklllOM.pdf
Testimonial: "It was the fuse. Thank you!"
