Question about Moultrie Game Spy D-55IRxt Game Camera
Trail Card Lock
When I turn the camera on, and go to menu, a message "Trail Card Lock" comes up. How do I unlock the card as it will not take photos.
Posted by Cathy Upton on
Anonymous
Check the sd card on the left side to make sure it not in the unlock position. If you have tried another sd card if still say trail card locked will need to call Moultire 8006533334 option 1 and 1 again for a live person to help you.
Posted on Mar 13, 2014
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Moultrie Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 12, 2013
How do I get rid of the trail card lock message that pops up on the screen when I turn my camera on ?
on the SD card on the left side of the card is a tiny switch,make sure it is pushed all the way up towards the contacts
Oct 27, 2014 | Moultrie Game Spy Mini M-80XD Infrared...
Menu screen nothing but lines.
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Mar 02, 2014 | Moultrie Game Spy D555i Trail Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Every time my daughter tries to take a photo using her Vivicam F314 camera, a message comes up says 'Card Protected', and she is unable to take a photo, she's taken the external memory card out...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Aug 25, 2011 | Cameras
My camera displays "No SD card" when I do have a
Hello beach.... remove the sd card and check the perimeter of the card to find the locking mechanism. If the card is in the lock position, move it to unlock. Then reinsert the card, turn on the camera and go into the menu. Find format. Format the SD card and then it should be good. Joe
Thanks for choosing Fixya!
Jan 04, 2011 | Bushnell Trail Scout 11-9830 Digital...
I have a message that states that my card is locked. How can I get this off?
SD memory cards have a tiny tab on one side of the card to unlock and lock the card.
If that does not work then the card may be faulty, try first removing camera batteries to reset camera, and then replace the card.
Jul 02, 2009 | Canon PowerShot SD850 IS Digital Camera
I attempted to unlock a 1.0 gb camera card today which has been locked. After attempting to unlock it using a utility knife (since the lever was missing) I gave up after trying to load and reload the...
Hi there.
Turn the camera on and go into the setup menu, look down the list for "reset" and reset it, then try another camera card.
Please post back the results.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Canon Cameras
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
The memory card is locked
If you are using an SD or MMC card, check if the lock button (on the side of the card - a tiny plastic that you can slide) is on the LOCK position. Slide it to UNLOCK position. If it's already in UNLOCK position, slide it to LOCK , then UNLOCK position.
Good luck and have a nice day!
Sep 30, 2008 | Pentax Optio 33L Digital Camera
Memory card
go to your menu section and disable the protection there.
Sep 08, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Moultrie Game Spy D-55IRxt Game Camera Logo
352 people viewed this question
Top Moultrie Video Cameras Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
