If you select the Forgot pattern button you will have the option to enter the Gmail credential used to configure the phone. If that doesn't work do the following after removing and placing back the battery:
1. Press and hold the power and menu key for few second untill you enter the restore menu
2. After the menu show choose "wipe data/factory reset "
3a. Select yes and your phone will be restore to default
3b. After finish choose reboot now
4. It will restart. Don't panic because it take few minute until complete.
5. Don't panic just wait. If there is no response in 10 minute just release your battery and put it back again and repeat from first step.
Note;
-use menu key to select.
-use volume up down to choose the menu.
-make sure u have enough power in ur batttery.ake sure u have enough power in ur batttery.
SOURCE: how do you unlock an samsung galaxy GT-S356
Go here to reset your Google password:
https://accounts.google.com/RecoverAccount
after that you should be able to use the Google Log-In to bypass your locked phone.
