Building Materials Logo
krisavia wright Posted on May 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set my car garage door opener
How do I set my garage door opener in my Toyota Camry xle to my home garage
Anonymous
Level 2:
Champion:
New Friend:
  • Expert 217 Answers
  • Posted on May 12, 2013
Anonymous
Expert
Level 2:
Champion:
New Friend:
Answers
217
Questions
15
Helped
108099
Points
371
Http://www.youtube.com/watch?v=sACFyGG-_bY
it depends on what kind of unit you have, but there are a few videos how to do it on youtube
2018 Toyota Camry xle. How do you change the temperature from Celsius to Fahrenheit please?
To change the temperature display from Celsius to Fahrenheit in a 2018 Toyota Camry XLE, follow these steps:
1. Start the car and locate the climate control panel.
2. Press the "Menu" button on the panel.
3. Use the arrow buttons to navigate through the menu until you find the "Settings" option.
4. Press the "Settings" button.
5. Scroll through the settings menu using the arrow buttons until you see "Units".
6. Select "Units" by pressing the corresponding button.
7. Use the arrow keys to toggle between Celsius and Fahrenheit.
8. Once Fahrenheit is selected, confirm the change by pressing the "Set" button or similar.
The temperature display should now be changed from Celsius to Fahrenheit.
How to replace a fog light bulb on a 2004 Toyota Camry
Video Description
The video above shows how to change the fog light bulb in your 2004 Toyota Camry. Not all models have fog lights - for many Toyotas, it depends on your trim level (XLE) or whether the fog light option was ordered when your Camry was manufactured. Fog lights are typically in the front bumper, below the headlight cluster and are helpful in poor visibility. If one fog light is burnt out on your Camry, we recommend changing both bulbs because the working bulb will be dimmer than the one you replaced and will likely burn out soon anyway.
When you change the foglight on your Camry, be careful not touch the glass part of the bulb with your fingers which causes the bulb to burn out earlier.
Other videos you might find helpful
  • Replace reverse light White light when you back up - yup, they burn out and you can replace them with bright LEDs
    2003 Toyota Camry XLE 3.0L V6
  • How to add transmission fluid If your transmission is running low on fluid, be sure to add some - find out how to do this here!
    2006 Toyota Camry LE 2.4L 4 Cyl.
  • Complete oil & filter change Sure you can take it in for a $19 lube, but are you OK with a stripped oil pan and cheap parts in return?
  • Fix leaky hoses The best way to fix leaking hoses is to replace them, but if you don't have time, a stop leak product might work for you
  • Set the clock to the correct time Is the clock in your car ahead or behind? Learn how to set it here!
  • Oil level check Cars burn, leak and otherwise dispense of their oil. Check your level frequently and top up when necessary
  • See all videos for the 2003 Toyota Camry
.2007 Toyota Camry XLE key fob not opening trunk remotely...also starting to have problems with it opening driver side door
First things first...replace the cheaper part first, the battery. It that works, great! If not, then you may need a new key fob then have it programed to your system.
1helpful
2012 Toyota Camry XLE sound system does not fade down when navigation gives instructions.
You have this listed in the home AC area and might want to list a new question in the car and truck area.
3helpful
My Toyota Camry 2001 XLE alarm keeps going off. Door sensor not working properly. How do I disable alarm system so my neighbours can sleep.
I had the same problem today - called Toyota dealer and they said to turn on the ignition, press the red button (alarm indicator), then turn off ignition, turn ignition back on, and it should be set to off. I am going to try this evening to see if it actually works. Also, he said if you don't have the button on the dash to look near the kick plate for a toggle switch and follow the instructions the same.
Lost power to power windows, door locks and sun roof.. I can not find the correct fuse that i think has blown. I have looked everywhere and all of the fuses are just fine.. 1992 Toyota Camry V6 XLE
Most likely a broken wire in the harness from front drivers door...open up and cut off the rubber boot and fix broken wires...they tend to break after a few thousand opens and closes...then wrap with electrical tape to replace the rubber boot...Lee
1helpful
Replace a burned-out bulb or headlight on a 2003 Toyota Camry XLE
I have similar issue with my 03 Camry XLE. I replaced the left side headlight bulb and the light still not coming on. Thanks in advance for the help.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
