Question about Mercedes-Benz Vehicle Parts & Accessories
Radio cc70 how to reset the radio code?
Posted by albert g licudine on
emad saad
Be704448000591
Posted on Oct 09, 2013
I need a code or whatever to get my radio on after repairs
Hello, Dixie -
The resetting code for your car radio should be with the owner's manual and other documentation that came with your car. The instructions for resetting the radio will be in the owner's manual.
If you don't happen to have that, then, you will need to contact an automobile dealership which sells your make of car.
When you find the code or obtain one from a dealership, I suggest you do what I have done: write the code inside your owner's manual on the page with the instructions for resetting the radio, so you will be able to reset the radio again, whenever needed. Note: When the car battery is replaced will be another time you will have to reset the radio.
Dec 21, 2017 | Cars & Trucks
Reset radio code
do you have the radio code ? if not contact a chrysler dealer as they can supply the code and the instruction to reset the radio which should be in the radio manual as well
Sep 27, 2014 | 2003 Chrysler PT Cruiser
Code radio
In the owners maunel you should have a card with the radio code on it.
The radio will only display EEE or OFF when the wrong code has been entered and the radio is locked depending on model - this is due to the battery being disconnected and the incorrect radio code being entered 3 times. You will neet to reset the radio. To do this the radio has to be on for either 2 or 4 hours - see the manual for your model. If you got the code from a card from Volvo, and it didn't work, then the radio has been changed or it has been reset by the dealer and your current code is invalid. You will have to pull the radio and find the serial & model number, and get Volvo to look up the code for that radio or the dealer may be able to lookup the radio code via vin# from Volvo. The dealer can reset the radio and enter a new code. When the radio is "ready" to accept an unlock code the display will say "codE". You will need this code if your battery is ever disconnected.
Mar 04, 2011 | 1998 Volvo V70
How to unlock car radio for volvo v70
Feb 26, 2011 | Car Audio & Video
I tried too many codes to reset the radio after changing the battery and now I cannot put the right code in. It just says Code Error. How do I reset the radio? Do I have to disconnect the battery to reset...
The normal method to reset a radio after wrong codes have been entered is to LEAVE SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itsel
This could take several hours.
Further useful information can be found here
Sep 26, 2010 | Car Audio & Video
Royal confetti shredder perforates paper but does not shred it.
You may have lost a bearing, try contacting Royal at 1-800-524-0799 to see if parts are available.
Jun 09, 2010 | Royal CC70 Shredder
Code for radio, changed battery and now no power
Check the manuel, the code may have been written in there and give you the instructions to resetting the radio, and check for a sticker in the glove box for the radio code. If you have a good relationship with the dealer they may even help you reset your radio without a fee or minimal amount.
Good luck and if that does not help you and they want a crazy amount to reset the radio try www.radio-code.com. Keep me posted
May 29, 2009 | 2005 Suzuki Forenza
Reset radio with code
Replaced the radio
Sep 09, 2008 | Car Audio & Video
Radio reset codes
I have a 2001 focus ..radio suddenly stopped playing after being at garage.  I thought that the battery was disconnected and the radio neede reset code, as it has a rad blinking dash anti-theft light.  i went to ford garage and they told me they don't have reset codes on the focus.  Is this true?
Aug 05, 2008 | 2001 Ford Focus
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
