Air bag light suddenly is on steady. took the car to a car wash and the red indicator light stayed on shortly after. the light flashes as it should when starting the car but then is on steady.
It is sometimes a indication that you have a bulb shorting out and needs replaced. Have someone help you check all your lights to make sure they are all working. If one is out, this should solve your problem.
DTCa
LFCb
LFC Priority
Description
B1318
Ignition Voltage Below 9 Volts
RCM Disconnected, Inoperative, or Lost/Low Ignition Feed
B1342
24
RCM is Faulted
B1231
19
RCM Crash Data Memory Full
B1921
21
RCM Bracket Ground Resistance High
C1414
29
5
Incorrect Vehicle Identification Code
B1887
15
6
Driver Air Bag Circuit Shorted to Ground
B1916
15
7
Driver Air Bag Circuit Shorted to Battery or Ignition
B1888
16
8
Passenger Air Bag Circuit Shorted to Ground
B1925
16
9
Passenger Air Bag Circuit Shorted to Battery or Ignition
B1932
32
10
Driver Air Bag Circuit Resistance High
B1933
33
11
Passenger Air Bag Circuit Resistance High
B1934
34
12
Driver Air Bag Circuit Resistance Low
B1935
35
13
Passenger Air Bag Circuit Resistance Low
B1901
14
14
Front External Crash Sensor Shorted to Ground
B1941
41
15
Front External Crash Sensor Open Circuit or Short to Battery
B2444
48
16
Driver Side Crash Sensor Internal Fault
B2445
49
17
Passenger Side Crash Sensor Internal Fault
B2441
42
18
Driver Side Crash Sensor Mounting Fault
B2440
43
19
Passenger Side Crash Sensor Mounting Fault
U2017
44
20
Driver Side Crash Sensor Communication Fault
U2018
45
21
Passenger Side Crash Sensor Communication Fault
B1993
36
22
Driver Side Air Bag Circuit Shorted to Ground
B1992
36
24
Driver Side Air Bag Circuit Shorted to Battery or Ignition
B1994
36
26
Driver Side Air Bag Circuit Resistance High
B1995
36
28
Driver Side Air Bag Circuit Resistance Low
B1997
37
23
Passenger Side Air Bag Circuit Shorted to Ground
B1996
37
25
Passenger Side Air Bag Circuit Shorted to Battery or Ignition
B1998
37
27
Passenger Side Air Bag Circuit Resistance High
B1999
37
29
Passenger Side Air Bag Circuit Resistance Low
B1892
30
Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open
B1891
31
Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition
B1869
Tonec
32
Air Bag Indicator Inoperative
B1870
Tonec
33
Air Bag Indicator Shorted to Battery
No Communication With the Restraints Control Module (RCM)
a DTC: Diagnostic trouble code b LFC: Lamp fault code, flashed on air bag indicator.
There is an issue. Clearing the code does not fix the problem... Pull the code and investigate what it indicates. Commonly, there is a sensor in the front that gets corroded connections. Replacement comes with new harness.
The Air bag warning indicator will FLASH and/or stay on STEADY if the system has detected a fault.. The fault can exist anywhere in the system, sensors, wiring, air bags, module, etc... I recommend you take it to your local Ford, Lincoln, Mercury dealership or a qualified reputable repair shop familiar with late model Ford SRS systems.. For Diagnostic trouble code retrieval and system repair...
Bill Andrade Ford Master Technician/ASE Master Technician
You have a bad Passenger Air Bag Deactivation Indicator. The bulb that shows when the passenger air bag is off.
Have seen alot of these go bad especially in police cars. The part number you need is 5W1Z-10A936-A.
If the only code 52 is flashing then system is ok and just needs to be cleared.Look behind the glove box and find the gray 2 wire connector.It will be on the left side behind the glove box and follow the proceedure below.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
Cycle the ignition switch to OFF and then to RUN.
Observe air bag indicator prove-out (six ±two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
Locate the Diagnostic Service Connector located underneath the glove compartment containing Circuits 631 (T/R) and 57 (BK).
Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground.
Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
Release short on Circuit 631 (T/R) to Circuit 57 (BK).
Diagnostic trouble code is now cleared from NVM. Next highest priority diagnostic trouble code stored in NVM (if one exists) will begin flashing
