Question about HP DeskJet 5150 InkJet Printer
Just need to know
I just would like to know if this printer HP5150 inkjet, if you can use a camera card? I want to make sure I can print photos, before I purchase this printer
Posted by lyon751 on
  • lyon751 Mar 17, 2009
    thanks alot for your help
Joe Fine
  • 628 Answers
There is no camera card capability for this printer. You can of course print using a camera card attached to your pc.
Posted on Mar 17, 2009
I am trying to print photos from a memory card and the printer will not read the card!!!
It is somewhat difficult to give a helpful answer as you do not mention what sort of image files are on the card and that could be the real culprit- If your camera produces RAW image files, then you cannot print from those - you need a format like JPEG of TIFF (as examples). Please give some more information so we can then help.
Sep 18, 2015 | Epson Stylus Photo R300 InkJet Printer
How to connect a printer to a digital camera?
If the photos are stored on the memory card (SD) in the camera, then remove the memory card from the camera and insert it into the memory slot in the HP printer. You can then print the photos that are stored on the memory card.
Jun 03, 2011 | HP Officejet 6500 Wireless All-in-One...
To print photos my machine requires a memory card. What card should I ask for and where/how do I install it?
Hello!
You can print photos from your computer too. Usually, people use memory cards from their digital camera, when they want to print photos directly from the memory card. If you do not have a digital camera or any other device that uses a memory card (i.e. a mobile phone), I am not sure you need one in order to print photos. However, here is the answer to your question:
You can use several memory cards in your printer, but only one memory card at a time! You can use:
  • SmartMedia, xD-Picture Card (fits in bottom right of the slot)
  • Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro
  • CompactFlash (I, II)
  • Secure Digital, MultiMediaCard (MMC)
Here is a picture, so you can see how to install them:
You can buy either one of these memory cards, it's up to you to decide which one you want.
Hope that helps!
May 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Will not print photo. Asks for card. Need to print from computer, not from photo card. It has worked in the past.
You just have to send the print request from the computer, if you press the photo button on the printer it will always tell you to insert the card. It knows how to print when it's sent a print request.
Jan 18, 2010 | HP Photosmart A610 InkJet Printer
My printer (Canon MP830) will not read my memory card from my camera. an SD card. You can print straight from the card. I press "Memory Card" as the source on the top of the printer and select "Print while...
Did you let the camera format the sd card before you took your pictures? Have you tried another sd card? Its possible the pc did not close the card properly so the printer does not see it. I would try another card before going any further. Make sure your setting on the printer is set to read only (in "Other" settings) if at read/write you will not be able to print.
Aug 17, 2017 | Canon PIXMA MP830 All-In-One InkJet...
HP5150 print cartridge light flashing
You should try confirmed working cartridges on your printer or use yours on another compatible printer around you before you can be sure. A new cartridge could come with factory fault you know. The other thing that can a suspect in this circumstance is the Carriage where the cartridges are installed. A defective or bad carriage will show up as a cartridge error. Be sure of these devices and the solution is around the corner. Good luck
Jun 03, 2009 | HP DeskJet 5150 InkJet Printer
I have a HP Photosmart 7160 and a brand new Fujifilm digital camera. I took 4 pictures and tried to print photos. When I place the SD 4GB card in it reads "memory card error" on the printer. What do I do...
You are using a new camera with an old printer.
Check the following:
- Try using a 1 to 2 GB SD card. The printer may not be able to hande one this size.
- Try taking a photo, in a smaller resolution, and save as JPG.
- Try plugging in the camera to the printer and print from the camera.
And the best option, is to transfer your photos to your computer, and print from there.
Take a look at a program called "Thumbs Plus" it has worked well for me. http://www.cerious.com/
If you have lost your manual, see: www.HP.com/Support for other answers.
Jan 01, 2009 | HP Photosmart D7160 InkJet Printer
Lines on a photo when printed
The print quality usually depends on the program you're using to print them on your pc.
Your camera only ever sends photos to your printer, so the best settings are already selected by the camera and it's built-in photo program.
Your printer doesn't 'know' whether your printing a document or a photo, so the settings for each program on your computer are basic (known as default settings), and need to be changed by you to get the best from your printer
Find the settings that let you alter the printers options (in Word, it's FILE \ PRINT \ PROPERTIES), and make sure the printer output is set to maximum quality, and that photo paper is selected as the paper type.
Some options such as 'maximum quality' only appear when you've chosen 'photo paper', and some printers (such as the ip4300) have seperate options for gloss or matte paper, so go through all of them until you see what you need.
Hope that helps :)
Oct 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Problem printing pictures
That card is probably too big for that card reader in the printer to read. You have to have a card reader that can read Secure Digital High Capacity cards. The most you can probably get out of the card reader on the printer is either 1 or 2 gb secure digital.
You might be able to get away with using the pictbrige connection on the printer and print that way as long as the memory card is loaded into the camera.
If that doesn't work you will have to get a card reader that can read SDHC cards.
Jul 04, 2008 | Epson PictureMate (C11C618001) Deluxe...
HP DeskJet 5150 InkJet Printer Logo
35 people viewed this question
Ekse
efs_perpends
efs_perpends
