SOURCE: beverage air mt 17
their web site says it is to maximize defogging.
http://www.beverage-air.com/images/glassDoorMerchandisers/manuals/809-005A.pdf
See if you can get to their web site. In the operations section, under initial start up, it talks about this. Can't find anything else on this.
Good Luck-Hope this helps.
SOURCE: Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
SOURCE: beverage air dd58 kegerator won't stay cold
the freon system is a sealed system. If you are adding freon, there is a leak. have the leak repaired and this should resolve the issue. Freon should not need filling but one time and only after the leak is located and repaired.
SOURCE: Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
