If the washing machine operates and cycles correctly, and only problem is overfills, then you have a bad water level switch or a bad membrane sensor (water level sensor).
If instead the machine get stuck on filling, and does not stop even if you advance timer, then the inlet valve is stuck on open, or the control board is faulty.
If machine is only two years old, call manufacturer and complain, even id limited warranty is one year, they may cover the part cost the same if they decide this was a factory defect (if it is inlet valve) coming up after two years.
SOURCE: water didnt shut off at medium load. overfilled
Sonds like faulty pressure swith/ or hole in air pipe feeding switch/or chamber blocked feeding air hose..Good luck
