Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
D Link DIR 635 - need to reset user name and password !
I have a d-link router DIR 635 - i have fogoten the user name and password to my system how do i by-pass this !
Posted by ap_saxton on
  • Anonymous Mar 19, 2009
    i have forgotten the network key
Anonymous
  • 33 Answers
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Posted on Mar 17, 2009
David Fitch
  • 170 Answers
You can hold the reset button in on the back fro 30 seconds or so and this will rest the router back to factory defaults
I am unable to setup a security password for my wireless network on my Apple Macbook using D-link wireless router model DIR-615
Enter a new login name and a new password for the administrator login. if you are a user then enter a new password and login name into the user login.
Apr 04, 2011 | D-Link DIR-615 Wireless Router
I don't know how to set a password on my d-link router because my internet is insecure. How do i do this? I have the default username and password, but i don't know what to do from there.
1.Open your Internet browser and type in the default IP address for your DIR-625 wireless router: 192.168.0.1. A window will appear asking for your DIR-625 wireless router network name and password. If you do not know your existing network name, enter the default network name, "Admin." Leave the password blank. If you have already set up a network name and password, enter it now. Select "Log In."
2.Select "Wireless Settings" from the left-hand navigation bar. Put a check mark in the box marked "Enable Wireless."
3.Type your new wireless network name for your DIR-625 in the box labeled "Wireless Network Name."
4.Type your new password for your DIR-635 in the box labeled "Pre-Shared Key."
5.Select "Save Settings" from the top of the screen to save your new password.
Feb 07, 2011 | D-Link DIR-625 (790069292637) Wireless...
I have lost my user name and pass word how do I retrive or reset?
The default user name is (admin)
the default Password (Leave Blank)
You will want to reset your router in order to reset to default settings to do that simply press and hold reset button located in the back of the router for 15 seconds or until router resets. You may need a paperclip to access the reset button. Good Luck
Jan 13, 2011 | D-Link DIR-615 Wireless Router
How ca i rename my d-link wireless router and put password on it? thx
you need to look underneath the router for something like this E.G http://192.168.01 it will be there somewhere on the router or documents you had with the router. once you have found this you need to open internet explorer and type it in the address bar as you find it, then this will acess your router so you can change the password and name and any other settings you want to change.it might ask your for a user name and password to log into the router but this should be on your router or on documents that came with the router. hope this helps
Aug 08, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
I have lost my password and i cant found it. can you help me?
EITHER RESET YOUR ROUTER. OR LOG INTO YOUR ROUTER THERE SHOULD BE AN ADDRESS UNDERNEATH THAT LOOKS SOMETHING LIKE http://192.168.01 ONCE YOU HAVE FOUND IT OPEN UP INTERNET EXPLORER AND TYPE IT IN THE ADDRESS BAR THIS WILL OPEN UP THE DLINK WEB PAGE FOR YOUR ROUTER IT WILL ALSO ASK YOU FOR A USER NAME AND PASSWORD THIS SHOULD BE WITH YOUR ROUTER UNDERNEATH OR ON SOME DOCUMENTS YOU HAD WITH THE ROUTER ONCE YOU HAVE DONE THIS AND LOGGED IN YOU CAN GO AHEAD AND RESET YOUR PASSWORD.
May 23, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
I do not have the installation wizard CD. Can I download the installer online?
YOU DONT NEED A CD TRY THIS
Point your Explorer at http://192.168.0.1
The Router default Username is admin
the default Password is just pressing Enter
Now you can accessRouter setup.
if it's new device, default user name and password are :
user : admin
pass : [blank
Dec 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Username and password needed
user : admin
pass : [blank]
Dec 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
How can i change the password of my D-link DIR-635 router
To change any settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable?
If not then you will need connect the computer to the router.
open the setup page and change the settings.
Click Here for step by step instruction
Dec 05, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
DIR 625-reset name and password
Since the router has reset itself, you can login it very easy. Go your web brower and in the space for the url address type 192.168.0.1 It will then bring up a screen for user name and password. The user name is admin and the password is left blank. Once you enter that information your logged in.
Good Luck
Mark
Jan 03, 2009 | D-Link DIR-625 (790069292637) Wireless...
I can not log in Call 1-8O5-225-669O We are 24 Hour Available Call Now To Customer Service
log on to your router > click on status> in left pane click on logs. Older logs are deleted when memory full.
If running the SYSlog utility you can save to a folder on your computer. You name the folder.
Link to manual:
ftp://ftp.dlink.co.uk/dir_products/dir-635/DIR-635_manual_10.pdf
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
14,071 people viewed this question
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
