RCA P46924 46" Rear Projection Television Logo
Question about RCA P46924 46" Rear Projection Television
Rca P46151 tv won,t turn on it has sat for about 5 years we had the Hv splitter replaced
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: My RCA Rear Projection TV Has Sound but no picture.
The tiny lites you see on the end of the tubes or crts are the filiments. This is a normal thing and if you didnt see those I WOULD BE WORRIED.. Now Who is they ?? who told you all that was wrong with the tv was the HI voltage block?? if your not a tech Dude your traveling into some very ,very dangerous territory!! Do you know I used to know three differant peeps who wanted to fix there own projection tvs BUT they are now all DEAD!!! They all electrocuted themselfs fooling around with the HI voltage circuit same as you did!!! Man You should stop and think what your doing before you treally hurt yourself.. Now for myour problem. How do you know the HI- voltage block was bad??? It wasent if you have the same problem that you started with. You probably have a bad flyback or hi voltage transformer?? Well any who I hope you dont get hurt tinkering with these sets as you can if your not carefull!!! CALL A PRO to assit you. Lifes not worth saving a few bucks for is it?? Good luck
Posted on Jun 13, 2006
Anonymous
  • 4402 Answers
SOURCE: my rca p60752eblg2
Yes it does sound like the flyback is bad, the only other thing that arc is a picture tube.
Posted on Dec 05, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: rca p60752eb
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
Posted on Mar 02, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: rca 52" projection tv 3 flashing lights, then powers off
If you see the flyback. That has a large red wire resembling a sparkplug wire. That wire goes into the splitter. There will be 3 more red wires coming from the splitter going to the CRTs. Just take the one wire that goes from the flyback and place that in the glass jar. Now some models have the splitter built into the flyback if thats your vase scenario you will need to replace the flyback. No way to test that properly unless you have a ringer to test it with. let me know how you make out.
Posted on Mar 19, 2008
Anonymous
  • 2992 Answers
SOURCE: I have a rca p52939 that won't turn on.
Failure of the HV splitter was a very common problem when I was doing these big screens on the road. The set won't come on if the splitter shorts. We used to test if that was the cause by pulling the HV input lead out of the splitter (leaving it still inside the plastic cup so it wouldn't arc anywhere) and turning the set on. Most often the set would fire right up (without picture of course).
I believe the RCA part number for the splitter is 205064, and it's available from a number of sources. I'm not home right now so I can't check. If I have the number wrong I'll post a follow-up comment.
Posted on Feb 13, 2009
When testing the hv flyback by turning on the tv, if tv stays on the hv splitter block is bad ,but what if tv turns off what you check next? thanks for the help.
first, I think you have this backwards----if splitter disconnected (look for physical signs or arcing or it burnt) the High voltage would come up and sizzle where it connects to the splitter.
If the set with the splitter disconnected still shuts down it is not the issue---got a D52 of some kind?
1helpful
CRT Question
Maybe, be safe. Run a wire with an alligator clip from the screwdriver shaft to the chassis ground while popping the anode off.
1helpful
Power supply sparks when tv is turned on
That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
7helpful
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
1helpful
2answers
I change module 267147r only works for 1 min
Most likely the modules you put in also blew again.
The reason is that there is a fault in another section of the set. For an example, the main power supply may also be defective. If its output voltages are not in spec damage will be done.
Many times when there are failures it is very important also locate the cause of the failure. This type of diagnostics can be involved and will require experience with a solid knowledge of the TV set, the proper test equipment, tools, and the service manuals.
The authorized service center is equiped, and has properly trained technicians that can service your set.
Jerry G.
Tv repair
HV splitter and flyback are common failure items. Remove the HV lead from the HV splitter that comes from the flyback, Place that into a dry glass jar secured so it doesnt come out. Then try powering up the set if the set powers up without shutting down the splitter is bad.
3answers
Rca tv hd52w140yx1
From your description ..actually this is a common problem and no simpley replacing the resistor will not fix it. this chasis has a problem with what is called the high voltage splitter.. there was a number of these made with a defective splitter. RCA HAS ISSUED a service bulliteen for certain models and serial numbers. the board and the splitter is generally replaced. (I just worked on one of these 2 days ago and got and order in for the parts) ......just reread the tech bulliteen.. the spitter which develops a crack is rca part number 258512 the resistor or the part that burnt is resistor a common 27k 1/2 watt 10% carbon resistor
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
52 in RCA
The T.V. has no lamp, it has 3 guns red,blue,& green. Unplug the lead that goes to the high voltage splitter(make sure t.v. is unplug). Then turn the t.v. back on if you hear the H.V. lead making a hissing sound continuously most likely the h.v. block needs to be replaced. Follow the lead from the flyback to the h.v. splitter, this will be the lead that unplugs at the splitter.
Open Questions:
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
