Wont switch on
Check your laptop DC jack loose connection or not. Your AC Adapter is giving accurate voltage or not mostly all
laptop works with 19 volt.
Remove battery and unplug AC adapter. Press
and hold power bottom for 30 sec. Now plug the AC adapter and placed the
laptop battery and Turn on.
If still not working need professional repair. You can be, but have to go throw with many things.
SOURCE: Packard Bell laptop switch off instead of hibernate
This is done via Windows Control Panel -> Hardware and Sound -> "Power options" -> "Choose what closing the lid does" and select 'Hibernate' instead of 'shut down' for both 'On battery' and 'Plug-in' power.
Let me know how you go!
Testimonial: "Very helpful and quick. Thank you:)"
Wireless problems with a Packard Bell PC or laptop can be caused by a variety of issues.
The best troubleshooting resources are the documentation that came supplied with the computer, and the Support section of the Packard Bell website.
Unable To Detect Wireless Network
If the Packard Bell machine is unable to detect a wireless network, the computer itself or the network could be at fault.
Check that a wireless signal is being broadcast via another PC or device, and check that are wireless adapter is installed, complete with the latest drivers, which are available at the Packard Bell website.
Unreliable Wireless Network
If the wireless connection is unreliable, intermittent or very slow, it suggests a problem with the Wi-Fi broadcast.
Try positioning the computer closer to the router broadcasting the wireless signal, or use a signal booster to improve the range.
Download and install the latest driver updates from the Packard Bell website and through the Windows Update tool.
Unable To Connect To Wireless Network
If the computer can detect the network but is unable to connect to it, a network security key may be required. This should have been configured by the person who set up the network. Consult the documentation that came with your router for details of how to change it or generate a new key.
Hope this helps
