Rheem pool heater not firing off
Have good water flow. Get SPK and CFH then get flashing flame symbol. No lite off of the burner.
Posted by Tom Childress on
Michael Green
  • 3,799 Answers
Try in the correct section, this one is for computer motherboards.
Posted on May 13, 2013
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Raypak 2100 fault
It sounds like your ignitor may be out. Everything else is good in the safety loop and the heater wants to fire. The last step in the process is the ignition of the main burner. Are you hearing a ticking sound? If not the spark is not being produced.
Apr 12, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Computers & Internet Logo
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
