Question about EdgeStar TWR181ES
Wine cooler not cool
How do I lower the bottom section, the top seems OK, what are top and bottom supposed to be?
Bernie Corrigan
    Master:
  • EdgeStar Master
  • 487 Answers
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
Posted on Apr 02, 2015
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
Jun 02, 2011 | Danby DWC283BLS Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Top evaporator fan not working and compressor hot , not cooling below 79 degrees
the top fan is not suppose to run all thetime only when its too cold and the heater kicks then the top fan will come on,you probley have a leak in the system
Nov 10, 2009 | Danby DWC283BLS Wine Cooler
I want the bottom to be reds and top to be whites
I don't think you'll be able to do this without some modifications to the unit.  The wine cooler is designed to blow cold air into the bottom section, and the top section cools down by spillover of cool air flowing between the glass door and the temperature control panel.
I guess if you could figure out a way to turn the panel that separates the top from the bottom you could make it work.  You'd have to switch the temperature sensing leads on the thermostat inside that panel(that would be pretty easy) and you'd probably want to flip the LED indicators so they read right-side-up.  The main issue would be that the screw holes for mounting that separator panel are all on the bottom, but when you flipped it, they would be on top with no holes in the walls to screw them into.  If you are willing to do that, you might be able to make it work as you would like.
Good Luck!
Dec 27, 2007 | Danby DWC283BLS Wine Cooler
EdgeStar TWR181ES Logo
229 people viewed this question
Top EdgeStar Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
Are you an EdgeStar Refrigerator Expert? Answer questions, earn points and help others
