B+ VOLTAGE SHOOTS UP TO 120V.after horizontal starts.screen excessively brilliant with slanting white horizontal lines(like retrace lines).IC TDA9111replaced; no use.rest all dc voltages are correct.kindly help...
SOURCE: monitor repair
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level. Just an note on the above - Begare - there are lethal voltages near the flyback transformer. you could get killed if you are not familiar with the insides of a TV-Monitor.
SOURCE: Monitor is totally dead
Through my past experience I mwould remove the solder point at the input power B+ line to primary winding FBT. If the HOT has shorted there will be no power.Straight to the point if you know where the HOT is , you can desolder the middle pin or collector of the HOT transistor. If you desolder the pin which result the power led light turn up. That indicates either FBT or HOT has shorted
SOURCE: screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
SOURCE: my 194wt worked great for 3 years, now it wont
Same problem as above. Had mine for 2.5 years and worked fine until I tried to turn it on this morning - won't come on at all. I have tried another power cable and verified that another monitor works on the old one.
