I have a yellow triangle with ! in it by each one in Control Panel. Tried everything I can find nad then some, except wiping everything out and starting over which I don't want to do. I have been told it is a Microsoft problem not a driver. Please help I need my dvd drives. One is a Philips DVD RW 8801 the other is a TSST DVD-ROM TS-H352C.
Thanks for any help you can give me.
Yellow triangle means that the driver is missing or is not working properly.
By
uninstalling the drive and cycling the power on and off and
reinstalling the drive the hardware wizard should recognize it as
"found new hardware" and look for an appropriate driver/s for it.
Conract me at my email so i give u support with remote desktop so i take control of your computer from here
[email protected]
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry key and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the registry editor.
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD
Along with Ekse's solution,
delete these ...
and restart the computer and see...
If it doesnt work, try system restore .
Or do update with microsoft... they probably have put out a fix for it
Hi, you need to delete the lower and upper filters I have a guide on this
Click the Start button, press run and type regedit.
more, and a video, on this pageIn the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
In the System folder, double-click the CurrentControlSet folder.
In the CurrentControlSet folder, double-click the Control folder.
In the Control folder, double-click the Class folder.
In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
In the right pane, click to select the UpperFilters registry value.
Press Del / Delete to remove the registery entry.
In the Confirm Value Delete dialog box, click the Yes button.
In the right pane, click to select the LowerFilters registry value.
close the regedit window.
Restart the computer.
http://www.fixya.com/support/r548399-fix...
I can look at it over remote support if you want.
http://www.fastsupport.com/334927017
above link will start a remote support session, it will work for a hour, if it complains just click on the manually download software link.
just write down [email protected] and I can help you with any problems that may come up.
Click on Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
I have a code 39 with 2 dvd's down. The upper and lower filters have already been deleted. Help
Thanks for all the help. Great working with you. Have A Great Day!!!
