Question about LG Vu CU920 Cellular Phone
My LG Vu touch screen just stopped working, what should I do?
I was walking down the hill and i felt it press up against my leg and when i got home the touch screen wasnt working PLZ HELP!!!!!
Posted by mdburnette on
  • 2 more comments
  • Anonymous Mar 18, 2009
    i woke up and my screen wasnt working
  • Anonymous Mar 31, 2009
  • lilmacsbinky Apr 09, 2009
    I plugged my phone in o charge, received a text, tried to answer but touch screen would not respond. Was working fine 1 hour earlier. No water damage, wasn't dropped, was just siting on the counter prior to plugging in. Tried turning off, removing the battery, sim & sd cards. Still not responding. All other buttons work. Is this common for this phone?
  • Anonymous Apr 10, 2009
    Same exact problem, was working one minute went to answer a text and the touch screen just stopped working. I had to call AT&T to get a replacement, but it's a refurbished phone, probably from people experiencing the same problems.
Scott Barowsky
    New Friend:
  • 3 Answers
I had this same problem. The best thing to try first for a free fix is getting a razor blade and starting to peel each layer off 1 by 1 start using a edge of a razor blade in one of the corners to do this and peel them off. I got through like 2 layers one all clear one clear w black outline b4 i got to one that looks like a throw back atari with a gold outline and 4 gold rectangles at the top. I think this might be some kind of contact strip though because the layer underneath has 4 gold rectangles also. i noticed that glue or something had spread from between these two layers onto the screen. I could even seen that i had anything on my screen other than a little rainbow discoloration with the other 2 layers of film on. I used light windex, water, and a lint free towel to clean off all the **** that was on the 2 surfaces but only peel pack top layer on 3 sides like a book and leave the sticky substance on outter edge so you can press the top layer back down i think I wiped too much glue on outter edge off bc it was working fine, then i had to get it really clean and now it senses when i touch but needs to be calibrated, but cant access through menu so Im looking for a button sequence to boot it. will update progress tomorrow
Posted on Apr 18, 2010
Anonymous
Whats wrong with it?
Posted on Mar 17, 2009
The touch screen is not working
form cable usb u can connect the phone and download lg pc suite if not solved change the tactil
Jul 09, 2010 | LG Vu CU920 Cellular Phone
Touch screen on lg view does not work
This is a common problem with the LG2_bing.gif VU
Take a look at the following link for videos about taking out the touch screen and how to put the touch screen digitizer back in the LG2_bing.gif CU920.
Remove and Replace Touch Screen on LG VU Cu920
Jun 05, 2010 | LG Vu CU920 Cellular Phone
Touch Screen Issue LG Cell Phone
try resetting it. I had the same problem. Apparently (I've been told) you need to recalibrate the touch screen on a regular basis. Eventually the whole screen will stop working, so do it now before it is too late.
Dec 23, 2009 | LG Vu CU920 Cellular Phone
I crack the screen
this is because only your screen must be broken, the rest of of the hard ware is properly, so jus need to replace the screen. thank you,, plz rate me..
Jun 29, 2009 | LG Vu CU920 Cellular Phone
LG Vu screen has frozen
It sounds like the touch screen/digitizer is broken This is the front of your phone that needs replaced. can be fitted by yourself if you buy ne onlne, prob not worth getting repaired by a repair centre if you are trading it in. You may be best selling it online for parts.
May 29, 2009 | LG Vu CU920 Cellular Phone
TOUCH PAD ON MY LG VU QUIT WORKING
You need to replace touch pad. Parts cost around $25. Fairly easy to replace. Once you see it you will know how to replace, Go on ebay and put in lg vu touch screen and you should pull up parts for your phone. Or just google lg vu replacement touch.
May 15, 2009 | LG Vu Cellular Phone
LG VU TOUCH SCREEN IS FROZE. CAN I GET PICTURES
Have you tried taking the battery out? And if that doest work you can call LG and they can replace your phone within warranty.
May 09, 2009 | LG Vu Cellular Phone
LG VU SCREEN PROBLEMS
you might have pushed down 2 hard on the screen if it is purple then thats the case
Dec 19, 2008 | LG Vu CU920 Cellular Phone
Lg vu screen responsiveness
You may try touch calibration.
To do this, first go to the main menu.
Choose the last tab on the right-hand side of the screen and choose 'More'.
Scroll down to 'Touch Calibration', selct, and then follow the instructions that appear on the screen.
Aug 23, 2008 | LG Vu Cellular Phone
Touchscreen doesn't work on my lg vu phone
I found a new touch screen replacement on Ebay for less than $20. Use the search criteria of Touch Screen Digitizer for LG VU. Then, use the link below to walk you through the replacement steps. I had no problems at all. Just make sure you snap the cable securely in place (near the last step).
Part1: http://www.youtube.com/watch?v=gTsHd2qS6GQ
Part 2: http://www.youtube.com/watch#!v=2ZspnRrZwCs&feature=related
The replacement part I purchased from Ebay already had the adhesive backing so I didn't need any extra glue. Be sure to carefully review the seller ratings and the product description. Avoid buying from sellers with poor grammar or no tools provided. Look for NEW products and ratings of 99% or higher for a reputable seller.
Jul 24, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
3,955 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
k24674
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
