Question about SanDisk Sansa e260 MP3 Player
My sansa e260 shows full memory in its screen
But when you check with windows, it is not. it has an unknown folder accesible only in the unit and shows 1117 songs in it. How can I clean it in order to be able to use it again?
Posted by Mario50 on
  • Mario50 Mar 24, 2009
    Thank you very much... Great!!!! It worked!!!!
ThaMp3Doctor
  • 8,597 Answers
Connect Sansa to computer
Double-click "My Computer" icon
Double-click Sansa icon (shows up as "Removable Drive" on some computers)
Select Tools --> Folder Options --> View --> check "Show Hidden Files and Folders"
Double-click Music folder
You should see your music files - you can delete at will.
Or:
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Posted on Mar 18, 2009
My sandisk sansa e260 mp3 player wont trun on it goes to the start up screen and thin keeps repeting that screen how can i fix this does any1 know?
Hi, the Sansa E260 is a portable MP3 player released by SanDisk in 2004. Several problems may cause the E260 to not function as intended from time to time. Common problems that occur are the device freezing, album art not appearing on the screen when a song is playing, pictures not filling the screen size and missing information on the separate tracks. You can troubleshoot the device and fix many of these common problems without the need of a service technician.
Reset
1. The Sansa E260 may freeze or function in other unexpected ways from time to time. This generally occurs when the unit's software has developed an error. Reset the device to clear the error and return the device to normal working operation. A unit reset is similar to rebooting your computer. You won't lose any data stored on your device.
To reset the E260, press and hold the "Power/Menu" button for about 15 seconds. The device will be forced to power down, during which the error will be cleared. You can restart the E260 as normal once the reset is complete.
Album Art Does Not Display
2. The E260 supports viewing album art on the display screen during the playing of a song. You may find that your album art is not showing up on the display when music is playing on the device. To fix this, make sure the associated album art file is in the same folder as the song being played. You will need to connect the E260 into your computer to move the album art files into the music folder.
Photos Aren't Full-Screen
3. Photos displayed on the E260 will not show up as full-screen shots if they are not cropped to the correct dimensions. The E260 software does not support stretching pictures to fit the full screen. To ensure your photographs will display on the full screen, crop the images to 128x64 in photo-editing software prior to transferring the image on the E260.
Unknown Artist or Album
4. The E260 displays information about each song using the ID3 tags associated with each track. ID3 tags hold information such as the artist name, album name, track number, year it was released and other information. If the E260 shows an artist or album as unknown, the information in the ID3 tag was not filled in. You can insert information into the ID3 tags from your computer.
To change the ID3 information, right-click on the music file and choose "Properties." Click on the "Summary" tab and choose "Advanced." The ID3 fields will display in the window. Insert any of the missing information and click "OK." When you upload the song onto your E260, the newly inserted information will show up in the display.
Hope it helped...
Feb 23, 2011 | SanDisk Sansa e260 MP3 Player
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
MP3 FILES LISTED AS UNKNOWN
Labeling Unkown Songs: open Windows Media Player and go to libary click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then syc with your sansa or media player then load songs to it........
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 - the mp3's that i load from my pc don't show up.
Try drag and drop from the music folder you have your music in.to the media folder on the sansa use windows explorer.........
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
I can't add new music folders to my sansa e260 because some go to
open windows media player and goto libary click on album artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... then syc with your sansa then load songs to it........
Mar 24, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 4GP Music Folder "missing"
Yup...had the same problem.
Start > Control Panel > Folder Options > View > Click on 'Show hidden files and folders' > Apply > OK
Done.
Oct 26, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260 isnt turning on
Well for starters, clear some memory. It sounds like the player is trying to turn on but failing as there is not enough free flash memory for it to use in a RAM like fashion. If youre using windows enable the view of hidden files folders. [Start> Control Panel> Appearence and Themes>Folder Options then browse through the tabs until you find a list which has the option "show hidden files and folders". Then plug in your e260 and go into the larger removeable drive. Then go into the folder "VIDEO" or "PICTURES" or "MUSIC and delete some files. Then once you have deleted at least 100MB, unplug and restart the player. This should fix your problem if it doesnt. Consider formatting the removeable disc, or updating the firmware. [However take extreme caution with formatting the disk to ensure that it does not contain the program files needed to run the player.
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
Freeezing
Hi. The symptoms you described may be due to corruptions in the player's music database (this player maintains an information pool on the music files you download to it). To resolve that, you would need to delete that database and let the player re-create a new one. To delete the corrupted database, let's do this: Step 1: Switch your player to MSC mode Step 2: Browse the player in "Windows Explorer", and look for the folder named "System" and/or "Data". Note: if you can't locate these folders, your Explorer may be configured to "Hide" system files and folders. To change that, please go to "Tools" on the menu list on the Explorer window, then choose "Folder Options". This will display a Window arranged in tabs. Select the "View" tab, find the "Hidden Files and Folders", then choose the "Show Hidden Files and Folders" radio button Step 3: Under the "system" or "data" folder on the Sansa E260, look for this file and delete it: "PP5000.dat" Step 4: Safely remove your Sansa E260. Then power it on. Your player will now either display "Rebuilding Library. Please Wait" or "Finalizing Update". Either way, it would re-build the database and hopefully resolve the error your player is encountering. I hope this helps. I love the Sansa E260!!
Mar 15, 2007 | SanDisk Sansa e260 MP3 Player
How do i delete pics from my sandisc sansa e260.
what you need to do is this. i cant help you if you have a mac but i can help you if you have a pc. for pcs, you need to plug in your player.once its connected, double click "my computer".in it, the player should have registered and their should be an icon that says "sandisk sansa e260" ( or something like that, i couldnt exsactly tell you considering my player is completely busted at the moment.)then you should see a bunch of files.the files will include album art,songs,and folders for videos or pictures.in the pictures folder you can access your pictures,and right click on the files you wish to delte, and simply just...hit delete.
Oct 08, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
136 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
