Refrigerators Logo
Posted on Mar 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 78182891 Coldspot with excessive water Collecting in Refrig
I have an excessive amount of water collecting in the refrigerator compartment of my Kenmore Coldspot unit. The source of the water appears to be from two holes in the top of the Refrig Compartment. Is this due to the Defrost Heater having to de-thaw the coils in the Freezer Compartment. Is this a symtom of low coolant pressure or too frequent operation of the defrosting heater? Model # 72202200
Ser# 2018829.
Fridge is filling up with water. If this is the same problem, will it re occur soon after defrosting the drain?
  • Gary Fresno Mar 22, 2009
    Peyton, I did exactly as you said, there was an excessive amount of ice buildup behind the rear cover on the coils on the ice maker side. I defrosted and removed all the ice buildup ran warm water down the drain tube and even finished it off with a vacum cleaner with a stinger tip. That was last wednesday. Today (saturday) there was more water in the fridge. Does this have something to do with the inlet tube for the ice maker?
    Thanks for your help.
  • Gary Fresno May 16, 2009
    No success, I have more water in the fridge. It seems to be coming from the back of rear coil cover. Do freezers normally put off that much condensation?
    I will try the copper wire. If you can think of anything else drop me a line. -Gary
Anonymous
Level 3:
  • Master 410 Answers
  • Posted on Mar 17, 2009
Anonymous
Master
Level 3:
Answers
410
Questions
Helped
229473
Points
1392
A plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
  • Anonymous Mar 22, 2009
    I think if you had a leaky icemaker or iemaker fill tube you would see icicles either running off the icemaker or running down the back cover of the freezer. I have a couple questions/suggestions:
    Is the freezer section abnormally cold? ie: temps lower than -5 f  this could cause the drain pan (which is aluminum) to run temps subzero and water will flash freeze in it. check to be sure the temps arent set too cold on temperature control. also if its getting too cold you would have problems with stuff freezing in fresh food section as well.
    its possible that another peice of ice or something didnt get cleared all the way when you flushed the drain the first time. ( altho it sounds as if you did a fine job).
    I have a recomendation. clean the drain again and while you have it pulle apart take a peice of solid copper #10 wire (make sure it is bare wire) about 4-6 inches long. wrap one end around the def heater, the blak rod running underneath the aluminum coil, and run the other end into the drain hole itself. this will transfer heat into the drain and prevent future freeeze ups.
    this should take care of drain problems altogether. if this doesnt fix it i would recomend aling a service company as you may have something happening that I cant see from this end. Do post back to let me know how it turns out. thanks Peyton
Model ET22DK or ET22DM water collecting inside refrig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Water in trunk compartment
prob seal around the window is bad
4helpful
GE Refridge #tbx21jablraa Water collecting in
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
1helpful
Water collecting in bottom of refrig Hotpoint
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
2helpful
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair:
Post bak if you have any questions and I'll gladly help you out Thanks Peyton
2helpful
-water is collecting in bottom of refrig
YOUR FREEZER DRAIN IS CLOGGED AND NEEDS TO BE CLEANED OUT-MIKE
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Hotpoint refrig model CTX21EPJR
there is a drain gulley on the back wall with a drain in the middle. this drain is blocked. push something flexible down it and follow up with a small jug of water to make sure it flows away freely
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
