The noise is the same as when you are putting on the burner and then the noise goes away once the flame is on. I took the knob off of the stove front to clean behind it and then moved the piece of plastic that sits behind the knob (for decoration), that's when the noice stated. Also, all 4 burners have a little "fire" thing popping (like when you first put the fire on). The noise is annoying to say the least. I do not smell any gas leaking.
What damage did I do to my stove????
It's a Jenn-air kitchen range that slides in. Model#FCG20510W
Serial #13325468QD
Indianapolis, IN
1995
SOURCE: Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
SOURCE: All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
SOURCE: Problem with Jenn Air Gas Range???
The back left burner dosen't uness it's on high to med heat...once i turn to med-low it started clicking. The back right works on any temp setting. The two front burners won't even ignite,jsut blue sparking and clicking. I am cooking on the back right one, it's the only one that works on high med and low.
I washed the range, around the burners and just the normal cleaning. The model number is JGS8750.
SOURCE: Dirty flames
You have a problem with either air supply or with the burner getting dirty. Clean out throughly with solvent type cleaners...no abrasives. You should only have blue flames.
SOURCE: Jenn-Air dual fuel range JDR8895AAB caught fire last week.
The exact same thing just happened to our same model last night. Did Jenn-Air fix it?
My popping sound is on all the time when the stove is on or off, i dont smell anything either and yes i see that little fire too. What is going on? Do i have a leak?
I am having the same problem. It is the igniter going off. My issue is that it is going off every 3-5 seconds, in use or not. Not sure how to fix the problem. I unplug the power cord for the time being.
I hope someone can answer this post.
