The ice cubes get stuck in the chute, and eventually refreeze into one big clump unless I constantly clean out the chute manually using hot water. The little white plastic door with a cushion in the center has fallen out, and I can't seem to be able to orient and hold it to re-insert it. The part is not broken.The ice cubes get stuck in the chute, and eventually refreeze into one big clump unless I constantly clean out the chute manually using hot water. The little white plastic door with a cushion in the center has fallen out, and I can't seem to be able to orient and hold it to re-insert it. The part is not broken.
You can't post conmments that contain an email address.
Is it the clump of ice that's connected to a mechanism? That's what you wrote. Melt the clump until the mechanism is free at last, free at last, thank god almighty, free at last. (MLK)
Checkthe freezer temperature. The proper freezer temperature should be around 5degrees. The warmer it is in the freezer, the more difficult it is to make ice.
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
the heating fan which turns on and off for defrosting is eathier stuck and wont start to defrost fast enough its a 35 part if you can do it your self when this happens its the defrost elment is going out
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places
Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
