Question about Dell Axim X5 Pocket PC
Can't install drivers for WIFI card
I purchased a VeriFone 11 Mbps 802.11b Wireless Compact Flash Adapter card for my Axim X5. I put the disc and the wifi card in my laptop and I can get on the internet. But can't seem to get it going in the Axim. It always reads "Unrecognized Card". Tried ActiveSynce and putting the drivers on a different Flash card. No luck..
  • csfmd296 May 21, 2009
    My Dell Axim V5 doesn't recognize my Verifone wireless Compact Flash Adapter.
Posted on Feb 14, 2011
  • bigcheese6 Feb 14, 2011
  • andy Jul 02, 2011
    presumably the drivers were installed on the axim? I downloaded a driver from here:http://www.wireless-driver.com/sparklan-...
    Used download 1 for the 4.2 ce processor. When I extracted the files it contained a setup icon. As the pda was already attached to the laptop it automatically installed on the pda.
    When the card was then inserted the green led came on flashing.
    Next I went into menu, settings, connections and enabled the wireless to find available networks. I'm sure that you know how to configure the settings for the router etc as you have already set up the system on your laptop. Use the same settings and it should work perfectly.
    Worked for me, the driver on the supplied cd was useless.
    Hope this helps
6ya staff
SOURCE:
I have a dell axim x5 and a verifone 11mbps 802.11b wireless compact flash card, i have managed to get the card working but i can't open any web pages! the little icon of the world in the top right hand...
I have the same setup and works perfect i used this driver http://www.mediafire.com/?nvk37m10lnp71p8 it only works in WM2003 and also male sure when your trying to connect your not synced with your computer or you'll also get that same ''the page you are looking for cannot be found''
Oct 05, 2010 | Dell Axim X51v Pocket PC
Good Eevening :
You could get original disk from ebay at times but all you need is the Activesync that can be downloaded from Microsoft. Get Active sync 4.2. The newer ones do NOT work with the X5.
Good luck with the wireless card. The Axim does not play well with many of them. (sometimes works but mostly not) Try drivers from d Link and be sure to remove the old drivers first.
Dec 02, 2007 | Dell Axim X5 Pocket PC
Wireless compact flash card installation on dell axim 5
Go to Wal Mart and buy a 1 gig SD card----- and then buy a AmbiCom 54G wireless CF card. Works perfectly in my X5.
Oct 30, 2007 | Dell Axim X5 Pocket PC
Confused about the WiFi on X5
It does NOT have integrated WiFi, you will have to buy a compact-flash card, the Linksys WCF12 works perfectly in mine.
Sep 14, 2005 | Dell Axim X5 Pocket PC
AXIM X5
To copy word documents, simply connect your device to your computer, click "Explorer" in ActiveSync, and then transfer the word document from your desktop to your Pocket PC. ActiveSync will do the conversion from Word to Pocket Word for you. As for wireless internet service, you need a wireless Compact Flash card and data service. Sprint is one of the few companies that offers this, and there is also the Pocket Spider from Enfora which can connect on some wireless networks.
Help : Can I access Memorysticks on AXIM
Since a SD memory card is about the same size [width and thickness] as a Memory Stick, I doubt there will ever be an adapter available between these two formats. There just isn't any room unless they came up with a very large adapter which would stick out and be unwieldly. You can get Compact Flash adapters (which are much larger) from a company called Pretec for about US$59.00, plus I'm sure there are others. I use a full sized PC Card adapter on my laptop to convert between the SD Memory card for my Axim X5 and the SmartMedia card for my digital camera and MP3 player.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Will this CF card work in my axim??!!
The Axim should support any compact flash memory card. So yes it should work.
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Dell Axim X5 Pocket PC Logo
2,016 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
