How do I access G2 stitch series on Bernina 1530 Inspiration?
The G2 Stitch series on the Bernina 1530 Inspiration is a set of decorative stitches that are programmed into the machine's memory. To access these stitches, follow these steps:
1. Turn on your Bernina 1530 Inspiration sewing machine.
2. Use the stitch selector dial or buttons to select stitch number 800, which is the starting point for the G2 Stitch series.
3. Once you've selected stitch number 800, you can use the stitch length and width adjustment dials or buttons to customize the stitch to your desired specifications.
4. To access the other G2 stitches, simply press the "next" or "previous" button on the stitch selector panel to cycle through the stitch numbers. The G2 stitches are numbered 801 through 811.
5. Select the G2 stitch you want to use, adjust the stitch length and width as desired, and start sewing!
It's important to note that the G2 Stitch series is not available on all models of the Bernina 1530 Inspiration, so if you're having trouble accessing these stitches, it's possible that your machine may not have them. In that case, you can consult your machine's manual or contact a Bernina dealer for assistance.
my screw that goes in my hand wheel is missing, I need to replace it
my screw is missing that goes on my hand wheel
I need to know what size screw goes in hand wheel to replace it
center bolt size
