Question about Stanley 100 ft. Tape Measure, FatMax
Stained doors the doors have streaky marks on them after being cleaned with cillit bang i have tried everything to remove the marks but cannot shift them Any ideas
Posted by Susan Muir on
Bruce
    Scholar:
  • 145 Answers
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel, polished granite, marble, porcelain, formica, enamel and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
I forgot to clean cillit bang off my stainless steel sink now itts got no shine and is marked
you could try reapplying more and clean it off in a timely fashion. or getting a good compound and power buffer
Nov 23, 2017 | Home
Streaky dirty washing
try running some cleaner through the machine on a hot 60-90 degree wash cycle with no clothes in. It may take a few goes to remove the build up of soapscum from the inner drum of the appliance
Apr 09, 2014 | Hotpoint Washing Machines
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
Hard water marks on windsheild and door glass how to remove
you can buy glass cleaners at any auto parts stores for water spots.
Oct 21, 2012 | Ford Transit Cars & Trucks
Soap scum on shower doors
We definitely want to stay away from any cleaning products that have an abrasive. Your local grocery or department store will have products specifically for cleaning soap scum. Some products will work better than others depending on the type of mineral content in your water. The best product is one where you don't have to do an excessive amount of scrubbing to remove the hard water and soap scum stains. Be sure to follow the manufacturers instructions for the best results. Again depending on the mineral content of your water you may have to try a few different products until you find one that works the way you want it to. There are also products you can purchase that you would spray onto the glass after a shower to prohibit the buildup of soap scum.
Jul 24, 2010 | RTO Shower Enclosure, 6mm" Tempered Glass,...
C5150: All color prints are extremely streaky and
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Nov 07, 2009 | OKI C5150n Led Printer
Cillit bang stainrd stainless steel cooker
Hi
The stain is probably 'etched' into the surface of the steel-- Only way is to take off the damaged layer-- A VERY fine cutting paste should do it - and as long as its very fine- you should still have the same shine!!
Jun 07, 2009 | Kitchen Ranges
I left cillit bang on the stainless steel hob too long and it has horrible stains on it
Use appropriate solvents to remove the plastic. If you are skilled sanding in straight lines and matching the grain in your metal use 180 grit - 240 grit blending and using your eye. You could also use scotch brite #7447 purchase at an automotive store. This pad after solvent or used with it could remove the plastic or both sand and pad.
Debruce Polish is the best our there at maintaining a pristine finish and it is eco-friendly and odorless, we use this in all our properties AND the ceramic cook tops it is safe for glass. It also removes rust... we just love it. We find DeBruce polish at debrucepolish.com.
May 09, 2009 | Thermador PSC364GDZS Gas Cooktop
Cillit bang damage to stainless steel hob
I left cillit bang on my Whirlpool stainless steel hob. It left a real mess and looked ruined, however I have a solution. You need Astonish cream cleaner, I got mine from the Kleeneasy catalogue, just get a damp cloth and rub gently all over. You might need to do it a few times, wipe it clean with kitchen roll then rub some oil (I used olive but baby oil is good) and it should buff up to a really good finish.
Mar 19, 2009 | Cooktops
Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Stanley 100 ft. Tape Measure, FatMax Logo
109 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
