Question about Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop
I have a laptop compaq f500. i did a recovery cd and now my wirless does not work. infact the icon at the bottom right is not showing.help -redstick
Posted by redstick_br on
  • Anonymous Mar 23, 2009
    i have the same problem and i had ask a compaq for this and they say the wireless is dead and you must send it to compaq and they will repair it free if you are still in warranty ,,,i need to tell you something about compaq or hp....HP OR COMPAQ IS ****!!!!
Anonymous
You need to ge the newest drivers for your wireless card. See if Compaq offers any wireless drivers. Another option is go to Microsoft update.
http://update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-US
Click on Custom rather than Express install.
Look on the left and there should be a high priority tab, a software tab and a hardware tab. Click on Hardware and see if it is offering drivers for your wireless card.
Posted on Mar 16, 2009
Rest my 2007 compac presaro f500 notebook to factory settings its asking fpr a eight digit factory password?
While it is always best to exhaust all other options before taking such a drastic step, sometimes the only course of action available is to restore your computer to its original factory condition.
If you have a Compaq Presario F500 with a damaged operating system or extensive damage from a virus or other malware, you may have no choice but to run the restore process and bring the unit back to its original factory state.
Place the restore CD into your F500 and shut down the unit.
Power the unit back up with the CD in the drive.
The F500 automatically boots from the CD and starts the restore process.
Verify that you wish to restore the F500 to its original factory settings.
The restoration process requires your verification, since it formats the hard drive and destroys the data.
You will need to verify that you want the hard drive to be formatted.
Insert the operating system CD when prompted.
Enter the license key for the operating system when prompted.
This license key information can be found on a small tag located on the laptop itself, often on the bottom of the machine.
Reboot the F500 when the restoration process is complete.
Copy any backup files to the F500, and then connect to the Internet and download any new updates from the Windows Update site.
This process can take awhile, so it is best to install the updates when you have a large block of time available.
You should, however, download them as soon as possible to protect your computer.
Compaq Presario F500 CTO Notebook PC support
http://h10025.www1.hp.com/ewfrf/wc/product?product=3316440&lc=en&cc=us&dlc=en&lang=en&cc=us If you are trying to recover a key of an already installed program on your computer there are freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry.
It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping.
Serial keys Location
Lift up your computer and look for a tag.
The tag will probably be located on the side of the computer, or on the bottom of the unit for a laptop.
The service tag is generally a large black and white tag and it will say "Service Tag Number."
Do not confuse this tag with the Windows tag, which may be located in the same area on the computer.
Mar 13, 2012 | Compaq Computers & Internet
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
Wirless router problam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
OR
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Nov 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
My compaq laptop cannot find any wireless and the
Can you describe what software/program you are using to establish the wireless connection? What colour Led is located near the wireless button? Ornage of Blue? It should switch from orange to blue, if it stays orange, the Wireless card is broken. This is a known issue on all HP DV6xxx, DV9xxx but also on allmost all Compaq V6xxx units. And has extended warranty, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN kr Gijs
Sep 10, 2009 | HP Compaq Presario F500 F700 and G6000...
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
Driver for compaq pressario f500
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-002&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us&h_lang=en&h_cc=us&h_query=presario+f500
Mar 21, 2009 | Compaq Presario Notebook
Wireless not working
Go to control panel click on system, navigate to hardware then to device manager than click on network adapters than right click on ( wireless network connection) and uninstall it, than restart computer and it will find new hardware. Click on new hardware icon and open available wireless networks and select network than connect.
Jan 25, 2009 | HP Compaq Presario V6000T Notebook
Compaq Laptop Network Adapter
Just to make sure im understanding the situation properly - you have a laptop and connect to the internet through a wireless network right? And then when you go to open up internet explorer or whatever program you use it basically says you're not connected to the internet.
It does sound like your wireless card has gone bad but when you say that it still has the icon down the bottom of the screen telling you that you're connected to the network, it sounds like it could be something else. It could be a range of things from there though, there are some viruses that corrupt something called the LSP and when that is broken it has the same symptoms as you described. Also it could just be a setting in your anti-virus. I know that Kaspersky Internet Security suite has a problem with its anti-hacker function that blocks internet from working like that.
Try disabling all of your anti-virus / firewall programs and then accessing the internet. If that works then its only a small problem. If it doesnt work and the icon is still there saying you are connected to the wireless then there is a small program to try running called LSP Fix, available at:
http://cexx.org/lspfix.htm
Other than that i'm out of ideas. Changing the wireless network card in a laptop does sound challenging though.
Hope my mini-essay helps,
Daniel
Oct 17, 2007 | Computers & Internet
Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop Logo
102 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
