Hi! i have a neptune washer, model # MAH5500BWW, and it's started leaking water all over. I checked all of my hose connections and everything seems ok. The water seems to be coming from above the inlets on the back of the washer and dripping down, i think. I removed the metal panel on the upper back of the washer, where the circuit board is, and it's wet inside there as well...we've also been getting "nF" on the LCD screen at the end of the cycle...any advice?
Nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
Mine did this a couple weeks ago, It was a problem with the drain hose. Make sure it is not pinned against anything behind the washer. I also poured Drano down the drain pipe within the wall. Problem solved. Now my washer won't fill. Pain in the rear. Looks like we're going to have to replace the inlet valves.
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. NF error in your Maytag is displayed due to no fill
condition, when the washer tries to fill but is unable to, nf is displayed.
Please check the water inlet valve for any clogs and obstructions, you can also
clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
