Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
the nut holding the trimmer head on is a left hand thread so you have to turn it clockwise to undo it
when the head is off you put the next attachment on and do up the nut in the reverse direction
Husqvarna GroupHusqvarna 122HD60 is a low noised and light weight hedge trimmer for domestic ... 23 inch. Weight. 10.8 lbs. Add to wish list Find a dealer near you. Manuals.
the trimmer head is a left hand thread
make like you are doing it up to undo it
remove all the trimmer parts down to a shaft then fit the plastic blade attachment
The head screws on to the shaft. be advised that it is a left handed thread You should have gotten a locking pin with the trimmer Turn the blade shaft until one of the holes in the drive disc aligns with the corresponding hole in the gear housing. • Insert the locking pin (C) in the hole to lock the shaft. • UnScrew on the trimmer head/plastic blades (H) in the direction of rotation
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Universal kits are available that will allow you to attach a brush cutter blade to just about anything that usually has a line head. The kit contains a selection of bolts, adapters, packing washers etc - you simply select the parts you need to attach the blade. The blade itself is not machine specific.
