Lets try this, Seprate you hardrive if you can (use this link for a step by step advice : http://laptoplogic.com/resources/detail.php?id=43). Once you have the hard drive seprated test it using a USB connector (or get it tested). If your hard drive works fine then just re-assebling it into the machine should work, else my friend we need to get the hard drive replaced for good.
You might need to check the BIOS if it recognizes the drive at all. You can access the Bios by pressing the setup menu button either F2 or F10 on the keyboard.
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased.
Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
which operating system ?
hope this helps
hope this helps
outstanding help. I know nothing about this world and the tips were great. way to go.
thxs
Stephen
is this a desktop or a laptop?
