WHEN STARTING IT MAKES A CRUNCH SOUND SOMETIMES...WHAT IT IS THAT NOISE?
SOURCE: fireblade rr 2001 starting problem
Your trickle charger has killed your battery. Replace the battery and all will be well.
SOURCE: clicking noise when starting
I would double check your battery FIRST. It could be a bad starter, but typically if it is clicking it might just be your battery. The least expensive and quickest solution is to hook it up to a charger, and see how it does. Cheers
SOURCE: clicking noise when trying to start car,battery is ok, wont start
That Clicking is the Battery causing it not to Start. You need to Replace that Battery or at Least put a Charger on it for a Couple of hours to see if you can Salvage it for a While.
SOURCE: 1990 Dodge Ram truck will not start, makes clicking noise.
the clicking noise is the starter solenoid, the heavy electrical contacts that supply 12 volts to the starter are burnt, you will either need to replace the starter slenoid contact set or the solenoid.
There
are many possibilities that can cause car to make noise.
It's
actually from where the noise is coming from. Front end or rear end. From
engine area or from inside the steering or from brakes.
There
is N-number of possibilities for the car to make grinding noise or any other
kind of noise.
For
step by step troubleshooting this problem, I suggest you to refer the help
links mentioned below. Its a complete solution with proper explanation to
identify the cause of problem: ------
Click
the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like
driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for
Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud
noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in
the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under
dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and
front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes
Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan
belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While
Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
There
It's
There
is N-number of possibilities for the car to make whining noise or any other kind
of noise.
For
Click
noise?
the front end?
Grinding noise?
belt Breaks?
Taking turns?
Grinding noise?
These will help.
Thanks.
There
It's
There
is N-number of possibilities for the car to make wierd noise or any other
kind of noise.
For
Click
noise?
the front end?
Grinding noise?
belt Breaks?
Taking turns?
Grinding noise?
These will help.
Thanks.
There
There
is N-number of possibilities for the car to make thud noise or any other
kind of noise.
For
Click
Vehicle making Clunk Thump Thud noise?
the front end?
Grinding noise?
belt Breaks?
Taking turns?
Grinding noise?
These will help.
Thanks.
Car makes whining noise like driving on rough pavement?
What are the possibilities for Clicking noise in car?
4X4 Truck makes roaring noise in the front end?
Heater makes clicking noise under dash on Ford Explorer?
Clicking noise under dash and front defroster not working?
Car Alternator Bearing Makes Grinding noise?
Engine makes noise and Cooling Fan belt Breaks?
Vehicle Makes Clicking Sound While Taking turns?
These will help.
Thanks.
