Lands Phones Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have tried everything I can to get the intercom to work and it just doesn't. Is there a setting I might have missed? The intercom indicator light won't even come on and the documentation refers to a intercom/intercom log buttom, which isn't on my phone. Any suggestions? Diane
  • Anonymous May 11, 2010
    What system/phone?
Anonymous
Level 2:
Champion:
  • Expert 211 Answers
  • Posted on Mar 28, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
211
Questions
0
Helped
75152
Points
371
No response. Closing
2answers
1helpful
Partner 18d phone wont program
Either you're not at ext 11 or you are pressing the RIGHT intercom button. It's FEAT 00 LIC LIC (where LIC is left intercom). If it doesn't work, try the same code from Ext 10. Also, you have to have an 18 or 34 button display set.
Radio shack intercom 43-493
Do you by chance have a DSS cordless phone that is interfering? Normally these should work well up to over a hundred feet for sure. Try swapping channels on the intercom units and keep away from metal (Like a refrigerator) and motors.
3helpful
2answers
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Intercome ringing
It sounds like the HFAI button on most of the sets is turned off. the HFAI (hands free answer intercom) button is located to the right of the SPKR key. With the handset down press the HFAI button. The green light next to it should light indicating that it is active. If the power goes out or if the phone is unplugged it will return to HFAI off status. hope that helps.
PLEASE, PLEASE try and help me...I can't tell you how much this would be appreciated. I have a Panasonic KTS4100 4 line phone (2 corded phones in our office, and one cordless). I have NO IDEA how to use...
Just in case you missed the manual:
http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
There are 2 conditions you need to be aware of
1 No DSL on the line
2. Set the intercom extension of the second phone
By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
Carl
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
5helpful
6answers
2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
