Question about Proscan 26LB30QD 26 in. LCD HDTV
How to remove base support from PROSCAN LCD TV( model 26LB30Q)
I am wall mounting the tv and just want to remove the base...no instructions in manual.
thanks for any help
Nick
Posted by nickburl on
  • 3 more comments
  • Anonymous Mar 22, 2009
    How to remove base support from PROSCAN LCD TV ( model 32LB30Q )
  • salmm Mar 22, 2009
    Just trying to find out if there are instructions to take the mount of the proscan 26lb30q before I try to figure it out myself.
  • Anonymous Mar 25, 2009
    any fix yet?
  • nickburl Mar 31, 2009
    actually you need to remove 4 screws at the lower back of tv...the two above the words "audio L/R" and "HDMI" and then the 2 screws just below these words. Replace the screws in original holes after removing base.
    Nick
  • Anonymous Apr 13, 2009
    I'm looking to purchase this same TV, did you find the solution to mount it? I can't find anywhere that it can be mounted?
Anonymous
    New Friend:
It works. Thnks
Posted on Apr 19, 2010
Anonymous
Remove the srews under AUDIO-L/R and HDMI-1.
Posted on Mar 30, 2009
  • Anonymous Mar 31, 2009
    There are no screws above audio-l/r, they are below, between audio-l/r and the recessed screws. Four screws to remove: two below audio-l/r and hdmi-1 and the two down in the recessed holes.
    PRO SCAN help desk phone number 888-977-6722 ext 201 A woman named Tina is of great help.
2answers
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
4helpful
4answers
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
4helpful
5answers
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
5helpful
4answers
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
3answers
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Proscan 26LB30QD 26 in. LCD HDTV Logo
Top Proscan Televison & Video Experts
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
