Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub 350 Scan-to-SMB instructions needed. Current desktop shortcut not working on pc.
Posted by mervinj on
Zaheer Ahmed
    President:
  • Konica Minolta Expert
  • 347 Answers
Call your technical service representative for the assistance........thanx
Posted on Jun 19, 2010
How to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
Jul 23, 2010 | Konica Minolta bizhub C250 All-In-One...
I install konica bizhub 350 to my network. scanning is going to SMB and very nice, but when i want to print from my PC, it did not print and also give no error.plz immediate help necessary. envoirment is...
Reinstall print driver to the PC using same ip address and print test print. next the same procedure go to web browser enter the ip address and choose administrator and the password 12345678. all your question will be in that area. scan, printing and network.
HH
Aug 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Cannot access to the scanner page
Your laptop is not configured properly to the network. You forgot to mentioned what type of scanning. ftp, smb, scan to email scan to box. But any way your IT can help you with this problem. If not I will email you the step by step to configure you laptop.
Jun 24, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can not make bizhub c252 scanning trough e-mail feature
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
Jun 01, 2009 | Konica Minolta bizhub C250 All-In-One...
How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Mar 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can't scan to smb
in smb server, create a folder and give all rights, to that folder, if youre in domain, it may need you to use a password, so create a user and password and give rights that user in folder then go youre printer ip address, and add a contact, choose smb and fill in the fields. if error occurs, then choose details and you see whats wrong
Oct 30, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scanning documents
You need to use the Scan to SMB function.
First create a folder, share it over your network.
Go to the MFP and under the scan to SMB enter the IP and path to the folder, enter the ID and password for the computer.
This will scan to the shared folder.
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,742 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
