I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I
set my printer so my printout fits the paper size I am using?
Solution: Use the
recommended Print Area MP240
Printing Area
To ensure the best print quality, the machine allows a margin along each edge
of media. The actual printable area will be the area inside these
margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (
Printable area (light blue):
The area where it is possible to print. (
However, printing in this area can affect the print quality or the paper feed
precision.
Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no
margins.
When performing Borderless Printing, slight cropping may occur at the edges
since the printed image is enlarged to fill the whole page.
For Borderless Printing, use the following paper.
Glossy Photo Paper "Everyday Use" GP-501
Photo Paper Glossy GP-502
Photo Paper Plus Semi-Gloss SG-201
Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially
reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced
quality. Use them only for test printing. You can perform Borderless Printing on
plain paper only when printing from your computer.
Depending on the type of paper, Borderless Printing may reduce the print quality
at the top and bottom edges of the paper or cause these parts to become
smudged.
See
A5,
A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See
Letter,
Legal.
See
Envelopes.
A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6
mm
* This page size can be used only when printing from your computer.
Recommended
printing area
Printable
area
Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6
mm
Recommended
printing area
Printable
area
Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1
mm
* Envelopes can be used only when printing from your computer.
Recommended
printing area
I have an IBM ribbon in the typewriter ending in 999 and I did the code Q, you could tell a slight difference but not much. Any other suggestions?
Not to sound dumb but I am blonde.....what is a solenoid and where is the L printer sideframe? Cannot locate in typewriter
