Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
I plug in my cruzer scan card or even my memorex scan card and the computer does not reconize them
Yeah, I have the same problem. The first time I plugged it in, it flashed once and I even saw the Safely Remove Hardware icon, but it suddenly disappeared and the orange light turned off. Plugging it into the back doesn't seem to work either. :/
So how do you fix it , my usb's orange light does not turn on and it's also not recoznuized by my PC then it gets really hot under it .....
Yes it on but the light is very dim and is still not reconized by my computer or anything else, also its still gets hot under the flashdrive.
