NRS Rock Tumbler Logo
Posted on Mar 16, 2009
Directions for Rock Tumbler
We have the Rolling Stones Rock Tumbler Refill Kit and it is missing the instructions. Could you email me the instructions?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
6415
Points
31
After many attempts to find the manual, I came across this site:
http://www.rockhounds.com/rocknet/archive/messages/1956.shtml
It seems you aren't the only one with the same problem!
I hope this is what you are looking for...
2answers
Rolling stones list of songs
The Rolling Stones have hundreds of great songs, but here's a site that has their top picks as well as a music video and a brief description of the song's history. Hope it helps!
http://www.thewildhoneypie.com/20-fave-rolling-stones-songs/
I need parts for a Rolling stones rock tumbler.
You can find a refill kit online. Here is one of the sites you can buy it from: http://www.amazon.com/Classic-Crafts-Rock-Tumbler-Refill/dp/B00004NKKY
Need instructions for rock tumbler
Directions for the NatGeo tumbler are apparently non-existent online. However, I did find the video below to be quite useful. It has some general tips that work with any brand of tumbler. I hope this helps out!
http://www.youtube.com/watch?v=dAi7qH_SJzw
1helpful
What do you do if you lose the directions?
You need to contact the suppliers and they will send you a set of instructions
http://www.giddyup.com/faq#57
What if I am missing, or have misplaced, my instruction guide for the kit?No problem! Just fill out the customer response form under the "Contact" tab, and we will email the instructions to you right away! Please be sure to provide your name, email address, and which kit you have purchased. You may also call Customer Service at 734-302-4444 to request instructions.
2helpful
We have a rock tumbler and have lost the instructions. How long are we to tumble each stage? I assume that the sand goes inside the tumbler with the rocks. We need some directions.
Fill the barrel most of the way with stones, add coarse grit, add enough water to just cover the stones and then clean where the lid seals carefully. Seal it up and run it for a week, dump everything into a colander and rinse. Don't run that mud down your drain because it will plug it mightily, run it outside.
Do the same process with the fine grit, run it for another week and rinse and admire.
lp
Where can i find a set of instructions for our edu science rock tumbler.
I used to have exactly that same rock tumbler. I have a bunch of polished rocks out in my garden that the kids and I made with that thing.
I don't have the instructions, but there are some perfectly great generic instructions on the geology.com web site: http://geology.com/rock-tumbler/rock-tumbler-instructions.shtml
I used these directions with great success.
28helpful
2answers
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from [email protected]
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 • Toys
Rolling Stones Rock Tumbler - no rubber ''O'' ring
Nothing high tech here. Try it without the o-ring. If the water does not start to leak out in the first 3 to 5 minutes of tumbling you will be ok. Stop it every day to check the water level.
Set the whole thing on a cookie sheet in case it does leak when you are not watching - you don't want a bunch of rock dust and polishing grit on your table or floor in the morning.
You will not damage anything by trying it without the o-ring.
I need to order a part for a Rolling Stones Rock Tumbler, and can't find out where to do so
Have you already tried Sears?
You could also try hobbypeople.net as they carry all the parts.
13helpful
3answers
I need instructions for the National Geographic Rock Tumbler.
Complete instruction manual to be found following the following link: http://www.sbdirect.biz/_download_files/NG09.pdf (my son also lost the instructions and I had to search the web to find another copy...
Mar 16, 2009 • Toys
Top NRS Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a NRS Toy Expert? Answer questions, earn points and help others
